Author Topic: Please explain to me this noise  (Read 3551 times)
Offline AstroScience
« on: 2013 August 10 04:50:56 »
Hi all,
I'm open and debayering 3 Light frames which were recorded with DSLR at 28 C temperature with ISO1600.
Noise evaluation for those 3 files reports:
Gaussian noise estimates:
s0 = 1.331e-003, n0 = 0.212 (MRS)
s1 = 1.282e-003, n1 = 0.283 (MRS)
s2 = 1.319e-003, n2 = 0.216 (MRS)
s0 = 1.359e-003, n0 = 0.210 (MRS)
s1 = 1.308e-003, n1 = 0.280 (MRS)
s2 = 1.349e-003, n2 = 0.214 (MRS)
s0 = 1.329e-003, n0 = 0.210 (MRS)
s1 = 1.280e-003, n1 = 0.280 (MRS)
s2 = 1.319e-003, n2 = 0.215 (MRS)
Now, to calibrate those I'm using Master Bias which created from 250 Bias frames at ISO1600 and Master Dark which created from 30 Dark frames at ISO1600 with exactly same 28 C temps.
After calibration with Master Bias and Master Dark with noise scaling and debayering I'm getting noise evaluations accordingly:
Dark scaling factors:
k0 = 1.491
VNG debayering: done
Noise evaluation: done
s0 = 1.013e-003, n0 = 0.556 (MRS)
s1 = 9.803e-004, n1 = 0.700 (MRS)
s2 = 8.908e-004, n2 = 0.544 (MRS)
k0 = 1.500
s0 = 1.024e-003, n0 = 0.555 (MRS)
s1 = 9.927e-004, n1 = 0.700 (MRS)
s2 = 8.972e-004, n2 = 0.541 (MRS)
k0 = 1.544
s0 = 1.007e-003, n0 = 0.553 (MRS)
s1 = 9.766e-004, n1 = 0.699 (MRS)
s2 = 8.818e-004, n2 = 0.541 (MRS)
After calibration it shows that only channels R got reduced in noise in all of the three files and channels G and B got injected with noise.
Can someone explain what's going on here?
I have also run calibration on those files without dark scaling and got those noise evaluations accordingly:
s0 = 1.042e-003, n0 = 0.417 (MRS)
s1 = 1.001e-003, n1 = 0.539 (MRS)
s2 = 9.275e-004, n2 = 0.388 (MRS)
s0 = 1.059e-003, n0 = 0.404 (MRS)
s1 = 1.019e-003, n1 = 0.525 (MRS)
s2 = 9.407e-004, n2 = 0.372 (MRS)
s0 = 1.037e-003, n0 = 0.412 (MRS)
s1 = 9.977e-004, n1 = 0.534 (MRS)
s2 = 9.198e-004, n2 = 0.381 (MRS)
Offline cs_pixinsight
Re: Please explain to me this noise
« Reply #1 on: 2013 August 11 14:21:03 »
Sergio, it looks like the noise dropped for all subs in all channels.  The exponent on the noise estimates went from e-003 to e-004, so the decimal point shifted after calibration.
I am curious why the dark scaling factor is so high given the matching dark.
Craig
« Reply #2 on: 2013 August 11 14:46:45 »
Hi Craig,
silly me, I'm totally ignored those numbers, thank you for pointing this out to me.
As for the high factor, all I know is that Darks were 420 sec long while subs were 540 sec long, all same temps.
That must be it?
Also, do I have to optimize my calibration files to look for a factor of 1 or less?
Offline Geoff
« Reply #3 on: 2013 August 11 14:54:21 »
Slightly off topic, but your darks should always have an exposure length that is no less than your subframe exposure.
Geoff
Don't panic! (Douglas Adams)
« Reply #4 on: 2013 August 11 15:09:57 »
Hi Geoff,
not off topic at all and I'm glad you joined conversation as I'm filling the empty spots of information in my head.
I were totally relying on the Vicent's paper on Master Calibration Frames:
"IC is optimized to work with calibration libraries: don't worry about differing temperatures and exposure times between dark and light frames. IC will always rescale the dark noise to match every light frame. "
What actually happens if darks are shorter than the subs, scaling cannot be properly calculated?
Offline Geoff
« Reply #5 on: 2013 August 11 18:30:23 »
Scaling assumes that the darks are linear, so that if I expose twice as long I get twice the dark current and if I expose half as long I get half the dark current. If this were really the case it wouldn't matter what length your darks were.  Unfortunately, this is only a reasonable approximation, so when you scale down, errors in this assumption are reduced, but when you scale up, errors are magnified.
Geoff
« Last Edit: 2013 August 11 21:55:27 by Geoff »
« Reply #6 on: 2013 August 11 21:32:45 »
Thank you, Geoff.
