Author Topic: Artifact around stars in registration process  (Read 2803 times)
Offline LorenzoM
    • My pictures
« on: 2013 August 08 13:05:19 »
Hello everyone.
I write because i have problem in registration step. On the left you can see the image after calibration, and on the left after registration. As you can see there are still hot pixel after calibration step, maybe because dark of my ccd are very old, and on the registrated image hot pixel appear more bright and dark ring appear around other stars.
Which is the reason for this strange behaviour? how can i prevent it?
« Last Edit: 2013 August 08 13:11:47 by LorenzoM »
Matter suggests to space as it needs to bend;
space returns the favor suggesting to matter as should moves
'John A.Wheeler 'Spacetime Physics'
http://www.flickr.com/photos/lorenzomassimi/
Re: Artifact around stars in registration process
« Reply #1 on: 2013 August 08 13:42:03 »
ringing due to negative lobes in lanczos interpolation transfer function. experiment with clamping threshold or try another interpolation method...
Offline Geoff
« Reply #2 on: 2013 August 11 00:21:13 »
Using a different interpolation method worked for me.
Geoff
Don't panic! (Douglas Adams)
Offline jeffweiss9
« Reply #3 on: 2013 August 11 18:10:36 »
I've always gotten this artifact on 2x2 binned subs with the auto/0.3 setting in ImageRegistration.  Using Bicubic Spline and a setting of 0.1 works fine for me on those.
-Jeff
