Author Topic: Batch Preprocessing Fits Header Binning problem  (Read 3563 times)
Offline Riccardo A. Ballerini
« on: 2013 August 07 03:16:43 »
Hi!
I am encountering problems with the Batch Preprocess.
I cannot preprocess my L(bin1) and RGB(bin2) all together.
I have to run two batches.
I take the frames with EquinoxImage.
Binned frames taken with Equinox Image on a Mac have have "IMAGEBIN - '2x2'" string in the Fits header
I see the script only recognize the strings: XBINNING and YBINNING.
Is it possible to enhance the script or is there a way to batch fix the FitsHeader of the binned rgb light frames (I can work manually on master bias, dark and flats ...but not the lights :-)
Thank you and clear dew-free skies to all!
Re: Batch Preprocessing Fits Header Binning problem
« Reply #1 on: 2013 August 10 01:15:41 »
any ideas?? :-(
« Reply #2 on: 2013 August 16 03:01:41 »
update
if someone is interested I enquired Darryl from Equinox and he said he will kindly integrate the complementary strings in the next revision
« Reply #3 on: 2013 August 16 03:23:13 »
Hi Riccardo,
The BatchPreprocessing script recognizes the XBINNING, BINNING and CCDBINX header keywords (the script only works with square pixels, so Y-axis binning is ignored). Including additional keywords would be very easy (you can do that yourself: just add the required keyword after line 668 of BatchPreprocessing-engine.js). However, the keyword's value must be a single integer literal equal to or greater than one, not an arbitrary string such as '2x2'.
« Reply #4 on: 2013 August 29 12:07:32 »
Sorry Juan I didn't noticed you answered my question, thank you very much and please forgive my delay
