Author Topic: Update Process Failed  (Read 4216 times)
Offline jeffweiss9
« on: 2013 August 04 16:07:08 »
Today (8/4/13) when I clicked on the updates, the
PI Core 1.8.0.1023 RC7 (cumulative bugfix)
failed to download with error:
File checksum error: C:/Users/Jeff/AppData/Local/Temp/PixInsight64-update/pixinsight.com/20130730-windows-x86_64-core-c.zip
which occurred when I tried again.  However, when I restarted to get the other four , I got another message saying that the update failed:
[2013-08-0423:01:47] Begin updater1
[2013-08-04 23:01:47] *******************************************************************************
[2013-08-04 23:01:47] This is PixInsight Updater stage one program version 01.00.10
[2013-08-04 23:01:47] Core application PID         : 2584
[2013-08-04 23:01:47] Target application directory : C:/Program Files/PixInsight
[2013-08-04 23:01:47] Source update directory      : C:/Users/Jeff/AppData/Local/Temp/PixInsight64-update/contents
[2013-08-04 23:01:47] Waiting for the PixInsight Core application to terminate...
[2013-08-04 23:01:54] PixInsight Core application terminated.
[2013-08-04 23:01:54] Waiting for things to stabilize...
[2013-08-04 23:01:56] Begin update process.
[2013-08-04 23:01:56] *** Error: Source updates database not found: C:/Users/Jeff/AppData/Local/Temp/PixInsight64-update/contents/updates.xri
[2013-08-04 23:01:56] End updater1: ERROR
I only see 1 failure, no successes in the log of the 5 downloads in the grouping.
Can this be fixed so I can get these updates (Win7 64)???
-Jeff
Offline jeffweiss9
Re: Update Process Failed
« Reply #1 on: 2013 August 06 13:11:35 »
I still get this error, every time I try to install this core update.  The other 4 updates installed fine.
It seems to me this file is corrupted on the server.
Hope someone can look at that.
-Jeff
« Reply #2 on: 2013 August 07 01:50:50 »
Hi Jeff,
This happens because you are entering an incorrect user name and/or password for authentication to download the core application update.
The server has valid update packages. The core 1.8.0 RC7 application prints an incorrect "file checksum error" message when it should say "bad authentication". This is a small bug that I'll fix in the final 1.8.0 release.
If you email support, we'll be glad to check your license data and provide you with your current user name and password. Be sure we'll fix this issue.
Offline jeffweiss9
« Reply #3 on: 2013 August 08 19:44:23 »
Thanks, Juan-
Entering the correct password took care of that.  I didn't make the connection.
-Jeff
