Author Topic: Weird Moiré pattern in a registered image  (Read 2534 times)
Offline bretm
« on: 2013 July 07 20:52:53 »
I am trying to process some DSLR problems I took this weekend, and the output has a weird pattern in them.  I normally use PI with CCD images.  This is my first attempt with a DSLR, so I suspect I'm doing something wrong, but don't know what.
The simplest repro case is:
- convert 2 CR2 images to FITs using BatchFormatConversion
- Register 1 of those images to the other (use 4196 as the reference, 4171 as the image to be registered)
- look at the registered version of 4171 to see the problem
- optionally, for a more psychedelic version, debayer the image.
A real workflow would include bias, darks, flats, etc. but since the problem shows up without them, so I'm leaving them out here.
Two CR2 files, and a sample of the bad output can be found here:
https://www.dropbox.com/sh/u1n8zaa4dag4vsm/S-oeM9GtaG
If it matters, these images were taken with a Canon EOS 5D MkII + 24mm lens on a non-tracking tripod.
Bret
Re: Weird Moiré pattern in a registered image
« Reply #1 on: 2013 July 07 22:42:31 »
you need to debayer before registration, it sounds like you did not do that...?
normally the flow is to calibrate the images in RAW mode, then debayer, then register, then integrate.
Offline bretm
« Reply #2 on: 2013 July 15 21:33:35 »
Thanks for the suggestion -- that was my problem.
