Author Topic: Batch Preprocessing integration parameters  (Read 2940 times)
Offline lómbido
« on: 2013 June 26 00:01:55 »
Good morning,
I am getting good results with the batch preprocessing tool, integrating with median and winsorized sigma clipping. When I try to do the same integrating the registered debayered images I do not get the same result. The integration dialog asks me additional parameters such as normalization and weights. Can anyone tell me the script default values in order to get the same results integrating by myself? Otherwise, whenever I want to add a new shot I have to preprocess everything again.
Thanks and regards
Offline sbock1
Re: Batch Preprocessing integration parameters
« Reply #1 on: 2014 February 26 09:31:00 »
Don't know if anybody will still read this, or maybe the thread opener has found an answer, but I have the exact same problem/question.
Anybody?
Stephan
« Reply #2 on: 2014 February 28 23:34:27 »
Hi Stephan, welcome to the forum.
First be sure you are using the same rejection parameters.
Also use in Image Integration the same Masters you have generated in BPP.
Saludos.  Alejandro
Offline Phil Leigh
« Reply #3 on: 2014 March 01 01:37:11 »
Leave the main "image integration" panel at the default settings
In Pixel Rejection(1), Set rejection algorithm to winsorised sigma clipping and normalisation to "scale+offset"
This mimics the BPP settings.
Then you can just re-run Image Integration and alter the sigma high/low settings in Pixel Rejection(2)
