Mike,
Another vote of thanks for SubframeSelector. I just did a little experiment with 20 luminance frames from last night. I went through them visually using Blink, and carefully selected the frames that I thought I should reject. This is a very subjective process, and I've never really liked doing it, plus it's quite slow for an entire night of imaging LRGB frames.
I then loaded the 20 frames into SubframeSelector, and sorted on FWHM, SNR, and Eccentricity, noting the frames outside the plus or minus 1 sigma levels. SubframeSelector detected exactly the same subset of bad frames, and best of all I used it to automatically copy the good and bad frames to sub folders for processing. This gives my a lot of confidence that I can now adopt a more quantitative approach to subframe selecting, plus it's much more efficient.
Thanks!
Sean
