Author Topic: BatchPre-Processing Error  (Read 3797 times)
Offline sreilly
« on: 2013 June 16 13:01:43 »
This is driving me nutz. I have loaded all my images, including newly made PI master flats using the instructions as posted in this tutorial http://pixinsight.com/tutorials/master-frames/en.html and yet BatchPreProcessing gives me an error that, well see attached:  What does it need to use my master flats. All master calibration frames were just made using the above process so if it's missing anything from the fits header it is because PI stripped it out. The raw calibration frames work fine when used in MaxIm and CCDStack so I know they are correct. Any help would be great while I still have some hair. I can upload one of these flats if need be but they are large files. (40.8 MBs)
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline sreilly
Re: BatchPre-Processing Error
« Reply #1 on: 2013 June 16 13:04:12 »
Not sure to remove the first image but it is the wrong one. Please refer to the bottom image as the error message.
-Steve
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline Harry page
« Reply #2 on: 2013 June 16 13:15:26 »
This is usually a naming problem  :surprised:  the name for the light and the flat must be the same  :D
use "add custom" and rename files if you need to
Harry
Harry Page
Offline sreilly
« Reply #3 on: 2013 June 16 14:28:22 »
Harry I appreciate the reply but am confused. I have not had to rename files in the past using this script so I'm unsure of how to rename them. I'va attached a screen shot of both flats and lights names as listed in the script. See below please.
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline sreilly
« Reply #4 on: 2013 June 16 14:33:16 »
As an example I have posted the master frames used after being made by the BPS as well as the names of the calibrated light frames the script generated if this is of any use. This was successful for the making of my M101 but all the flats were raw and the masters created using the script instead of my using the Image Calibration and Image Integration processes as described in the tutorial mentioned in the original post.
-Steve
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline cfranks
« Reply #5 on: 2013 June 16 17:16:45 »
I have the same problem.  Easy to fix but I feel it should not happen.  The Master Flats created have an amost blank Fits Header.  I add the FILTER and BINNING keywords and Batch PreProcessing works perfectly.
Charles
Offline sreilly
« Reply #6 on: 2013 June 16 17:46:00 »
Charles,
I added the FITs header info and it does indeed work now. Seems strange that the flats made this way are missing needed info.
Thanks Again
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Offline cfranks
« Reply #7 on: 2013 June 17 03:28:44 »
Steve,
Glad to have helped.  I think you may find that all integrations so made are missing the Fits header data.  eg. Darks don't have Temp, Binning nor Exposure etc.
Charles
Offline cs_pixinsight
« Reply #8 on: 2013 June 17 11:30:19 »
Please file this as a bug in the script so this issue doesn't get lost because you are now manually fixing the files.
Seems like this should be an easy one to fix.
Craig
Offline cfranks
« Reply #9 on: 2013 June 17 19:00:36 »
Craig,
It is in the ImageIntegration module and, I believe, has been mentioned previously.
Charles
