Author Topic: How do you perform a Gaussian Blur?  (Read 8897 times)
Offline twade
« on: 2008 January 26 12:15:26 »
To all,
I probably should know this, but how does one perform a gaussian blur in PixInsight Standard?  Basically, I'm trying to imitate the Photoshop technique of combining two images, one of short duration and one of long duration, using a blurred mask of the long duration image.  This is a common technique to handle high dynamic targets such as M42.
Once I've created the mask, how do I combine the two images using the mask?  I'm sure I'll be using PixelMath, but I'm unsure of the proper equation.
Wade
Offline twade
« Reply #1 on: 2008 January 26 12:33:38 »
To all,
I figured out how to mimic the Gaussian blur by removing layers in ATrousWaveletTransform.  Now I just have to figure out how to combine the two images using the mask.
Wade
« Reply #2 on: 2008 January 26 12:58:27 »
Hi Wade
We'll implement an advanced Convolutions process, that will incorporate the Gaussian blur. Maybe we'll also write a stand alone process, with other options, but this has not being decided yet.
Anyway, so far using ATrousWavelets is a good way to emulate this. Also you may use ACDNR, or even the Wienner deconvolution with a way too big noise estimation. A more rigorous gaussian blur can be applied with a script... I think that somewhere was the code already wrote by Juan.
Offline Jack Harvey
Gaussian Blur
« Reply #3 on: 2008 January 26 13:02:56 »
I mimic it by using Atrous Wavelets and setting the Bias for the first couple of layers to -0.1 to -0.3.
Jack Harvey, PTeam Member
« Reply #4 on: 2008 January 26 13:12:42 »
Hi Jack
For small bluring effects, this is a good way to go. For larger "radius", it is better simply to discard wavelet layers, using the 3x3 or 5x5 Gaussian kernels (I recommend the 5x5 one).
Offline twade
« Reply #5 on: 2008 January 26 13:24:28 »
Carlos and Jack,
Thanks for your help.
I created a pretty good mask by setting the Wavelet Layers to Linear with a value of 6, using a 5x5 Gaussian scaling factor.  I then removed the first 9 layers.  Afterward, I used the clone tool to "paint" the rest of the image to black, leaving only a portion of M42.  I then associated the mask to the long exposure (Select Mask).  Using PixelMath, I added just the short exposure to the Expressions list.  Finally, I dropped the process icon associated with the PixelMath instance onto the long exposure.  This seemed not to work since I got a "duplicate" of the short exposure as the result.  What am I doing wrong?
Wade
Offline twade
« Reply #6 on: 2008 January 26 18:20:36 »
To all,
I finally figured out the formula.  Here it is:
(1-mask)*m42_long+mask*m42_short
I'm not sure why the other technique didn't work (i.e. adding the mask to the long exposure through the Mask menu and using just the short image in a PixelMath instance).
Wade
Offline twade
« Reply #7 on: 2008 January 26 19:25:37 »
To all,
Here's the result of the combination.  Let me know what you think.
2400x2400:
http://tinyurl.com/38g7sl
1600x1600
http://tinyurl.com/2uegsp
Wade
Offline Jack Harvey
Nice
« Reply #8 on: 2008 January 27 06:26:45 »
Wow that is a big field of view.  Nice job with the processing!
