Author Topic: Merging two RGB's one being HA  (Read 3336 times)
Offline grahamxx
  • Pixinsight Newby
« on: 2013 June 11 04:19:33 »
Hi Guys
My first post question so sorry if this is already answered. I couldn't see the exact question listed.
Over two separate nights I have taken shots with my DSLR. First night I took shots with a CLS filter and the second night I used an HA filter. I ran both sets through Deep Sky Stacker and ended up with 2 tif files which I am trying to put together in Pixinsight. I have watched Harry's demo Tutorial but it doesn't quite match what I am trying to do. Here is the difficulty.
I have used Pixel Math with process icons from Harry's web site. I have used Channel combination and LRGB Combination all to no avail. I get messages saying cant do this with Gray files. Or if I try RGB it says wrong file type. I have tried it with Linea files and with Dynamic files. I would be most grateful if somebody could give me a workflow that I should stick to. I spent many hours on this and I don't want to have to go back to PS if I can help it.
I am so pleased so far with Pixinsight and I am coming up to the end of the trial period. I can't believe how well it deals with gradients
Many Thanks
Graham
SW 250pds, ED110 and VC200L HEQ6pro pier mounted. Canon 1100d. SW80, Synguider
Re: Merging two RGB's one being HA
« Reply #1 on: 2013 June 11 06:20:24 »
You may need to convert "gray" (1 channel) files into color (3 channels). I dont have PI with me, but it is probably in Processes/Color*.
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #2 on: 2013 June 11 11:48:14 »
Hi Graham!
You should get RGB TIFs if you calibrate and stack your  DSLR images in DSS.
You should not get a gray TIF...!
Also the Ha Image will be an RGB Image.
I would either use PixelMath or the Script HaRGBCombination.
Would never use ChannelCombination or LRGB for mixing Ha (RGB) into plain RGB.
Have a look at my PixelMath Video IIa:
http://dl.dropbox.com/u/57910417/Video08_PixelMath_IIa_english.wmv
it shows at the end (12:00 Min.) some of many Versions how you could mix Ha and RGB.
The processes of the Video are downloadable from:
http://www.werbeagentur.org/oldwexi/Daten/PixelMath_IIa_Processes.zip
Gerald
Offline grahamxx
  • Pixinsight Newby
« Reply #3 on: 2013 June 11 12:35:51 »
Hi Gerald
Thanks for taking the time to reply.
Initially I did have the two RGB's you would expect. However I have tried all types of extracting the files as the RGB ones would  not seem to merge correctly. I perfectly accept I have done something wrong so I will have a look at the video's you suggest. Will let you know how I get on.
Thank you   :)
Graham
Offline grahamxx
  • Pixinsight Newby
« Reply #4 on: 2013 June 11 12:37:20 »
Thank you for your suggestion. Will have a look at that :)
Graham
Offline grahamxx
  • Pixinsight Newby
« Reply #5 on: 2013 June 11 13:51:15 »
Hi Gerald
I had a look at the video. Massive help there. Hope I can understand it all after a few watches.
Appreciate your support and help :)
Graham
