Author Topic: Getting the star colours to show up ?  (Read 5738 times)
Offline boris sputnik
« on: 2013 June 04 14:41:31 »
Can someone help me bring out the colours of the stars when I process ? Where in the process and what tools should I use ?
Anyone have an idea !
Thank you !
Maxx
Nexstar 8SE ,stellarvue SV80ST ,HEQ5 pro ,Canon T3 (1100D) ,0.63 focal reducer/corrector ,CLS clip-in filter , Magnif.mini SSAG Guiding kit ,BacyardEOS ,PHD guiding
Offline DMouse
Re: Getting the star colours to show up ?
« Reply #1 on: 2013 June 04 19:41:09 »
Hi, use a star mask to protect the back round and then use Curves to ramp up the Saturation in the stars. This will stop the background from getting messy.
Clear Skies
Paul
« Reply #2 on: 2013 June 05 01:10:40 »
Clear Skies
Paul
Thank you Paul ,I will try that...but the galaxy will not get protection either ???
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #3 on: 2013 June 05 06:14:42 »
Here in my article you'll find some useful information:
http://pixinsight.com/tutorials/NGC7023-HDR/en.html
Vicent.
« Reply #4 on: 2013 June 06 12:12:26 »
Vicent.
Thank you very much Vincent !
Offline Warhen
    • Billions and Billions
« Reply #5 on: 2013 July 12 12:49:02 »
Dosvedonia Boris, One 'trick' for star color is not to lose it in the first place. Be sure that stretches don't saturate (as in clip) highlights. The MaskedStretchScript is fabulous for this. Certainly, as stated, star saturation can be later enhanced in a couple of ways, generally Curves/Saturation or ColorSaturation with a mask.
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline Tom OD
« Reply #6 on: 2013 July 21 18:06:06 »
That's a good tutorial Vincent, but I was wondering how do you know the median value of the HDR image was 0.43 that you then used in the Masked stretch script?
Thanks Tom
Offline Bob Andersson
« Reply #7 on: 2013 July 22 01:29:01 »
Hi Tom,
I developed my "Repaired HSV Separation Script", discussed in this thread, to help with this. If the script isn't already part of your PI install then that thread also includes a download link.
Bob.
TEC 140 'scope, FLI ML16803 camera, ASA DDM60 Pro mount.
Offline Tom OD
« Reply #8 on: 2013 July 22 23:31:16 »
Thanks Bob I'll look that up. I
Tonight I spent some time practising this but I didn't get some good results. I have 2 more questions. Based on the following quote from the tutorial
"This process must be masked with the mask we have built in the preceding paragraphs. This mask has very low pixel values (0.1 to 0.2 on the star edges), so we can apply the same PixelMath instance iteratively to control the intensity of the process"
1) Do I use the mask on all 3 images that are used in the Pixel math formula to join the masked stretch to the HDR LS image, or just one or 2 of them?
2) How do you do the pixel math 5 times. Do you swap the new image into the pixel math formula?
Thanks Tom.
Offline Tom OD
« Reply #9 on: 2014 January 15 14:44:39 »
I've ended up back at practising the Masked Stretch script, and I have also ended up with the same issues and questions. I 'm attaching a screen shot showing that I have got to the steps as shown in the tutorial, but the resulting Pixel math formula image has blurry large scale details.
So do I use the mask in all 3 images, or just the MS version?  In the screen shot I have used the mask on the MS image, and I have it protecting the stars, they are red. I thought this would allow the unprotected area to get substituted with the HDR stretch.
Any ideas anyone?
Thanks Tom
Offline Phil Leigh
« Reply #10 on: 2014 January 16 04:36:14 »
You need to be careful with the Masked Stretch script - it doesn't always mask the larger stars correctly - you will need to play with its masking parameters on some images. A classic sign is that larger stars end up with red centres surrounded by a white halo.
