Author Topic: Image Integration bug under Windows RC7  (Read 4866 times)
Offline mcgillca
    • Astrobin Website
« on: 2013 May 28 13:02:33 »
Hi - I have been having odd flats recently, but have been making do with old versions until new dust motes caused me to seek a solution.
When I use the Batch PreProcessing script, I was getting flats with an overall illumination of 0.02.
This is odd, since each flat frame has an average illumination of about 0.32.
I traced the problem to an issue with the Image Integration module.
I can integrate 10 callibrated flat frames, each of which has an average illumination close to 0.3, but the integrated field has an illumination of 0.02.
I tried with several different normalisation techniques, but found all but "No Normalisation" gave a problem.
I tried replacing the master flat frames with these, but the batch processing script didn't recognise them.
I am happy to post my frames somewhere if this would help.
Colin
Paramount MX
Ikharos 8" Carbon Truss RC
Atik 460ex
Atik EFW2 with Baader LRGB and HA SII OIII
ONAG with Atik 314L+
http://www.astrobin.com/users/mcgillca/
Re: Image Integration bug under Windows RC7
« Reply #1 on: 2013 May 28 14:28:37 »
what type of input files are you using?
Offline mcgillca
    • Astrobin Website
« Reply #2 on: 2013 May 28 14:46:04 »
Fits files, created by CCDsoft, taken from an Atik 460ex.
Colin
Paramount MX
Atik 460ex
« Reply #3 on: 2013 May 28 14:53:16 »
Are the images you are integrating bias-subtracted? If so, then you should use multiplicative normalization only (if used).
As long as the only transformation applied to the flat frames is a multiplication, it doesn't matter the average value, since it is normalized when you perform a image calibration.
Offline mcgillca
    • Astrobin Website
« Reply #4 on: 2013 May 29 01:52:44 »
Yes, the flats are bias subtracted (at any rate, they have been through the  Batch Pre-Processing Script and are in the "calibrated" folder.
Using multiplicative normalisation gives an odd result, as per my original post. I also tried out other methods but found that only by using no-normalisation did I get an answer that looked anywhere near reasonable. The others were about 16 times too low.
Colin
Paramount MX
Atik 460ex
Offline mcgillca
    • Astrobin Website
« Reply #5 on: 2013 May 31 03:26:25 »
I have also found that I can get correct masters by restricting the number of flats. I have found some filters can cope with 10, but others require a maximum of 6. Beyond that, I get the 0.02 value again.
Any ideas?
Colin
Paramount MX
Atik 460ex
« Reply #6 on: 2013 June 01 14:27:13 »
this is quite strange - if we can get juan's attention then perhaps you can upload your .fits files somewhere and he can take a look. or maybe carlos can look at it, i dunno.
« Reply #7 on: 2013 June 01 16:09:52 »
Sorry, this one seems a lot "lower level" for my skills. Let's wait for Juan.
« Reply #8 on: 2013 June 02 00:02:56 »
I cannot reproduce this. As always, I really need some data to try to reproduce/understand/diagnose the problem.
Just to rule out a common cause of errors. Are these files in 32-bit floating point format?
(...back to weekend standby mode :) )
Offline mcgillca
    • Astrobin Website
« Reply #9 on: 2013 June 03 04:26:01 »
Thanks, Juan.
I will check, but I'm pretty sure they are 32 bit (they've been calibrated via the batch pre-processing script).
I can upload the files - where is the best place to load them, or can you let me have your email so I can add you to my dropbox account?
Colin
Paramount MX
Atik 460ex
