Author Topic: No color after BatchPreprocessing  (Read 2669 times)
Offline dcbrown73
« on: 2013 May 27 12:17:29 »
I took several M57 images, but only kept seven of them.  I took 10 darks, 20 flats and 20 bias images (first time taking bias images).
I use Batch Preprocessing to stack everything, but the outcome was a master light that was black and white.  When I open the light master, it says "GRAY 1:4 Light_Binning_1".
The image was taken with a Canon 650D (4Ti) unmodded.  I've taken images of M57 before and didn't have this issue.  The only thing different is I have flats and bias frames with this stacking.
The light frames that I used to stack these, open up as RGB frames when I open them individually with PixInsight.  So, they were color to start with.  :/
If anyone could tell me where I went wrong, I would be very thankful!
David
Re: No color after BatchPreprocessing
« Reply #1 on: 2013 May 27 13:28:55 »
Check the CFA Checkbox (Color filter Array) when using the BatchProcessing script.
Offline dcbrown73
« Reply #2 on: 2013 May 27 14:18:09 »
Thank you very much!
