Author Topic: CatalogStarGenerator does not work in PI 1.8  (Read 3477 times)
Offline ppistor
« on: 2013 May 24 03:01:57 »
I have successfully used the CatalogStarGenerator in an earlier version of PI (as of May 6, 2013).
Current attempts deliver empty results ("no stars painted").
Offline Andres.Pozo
Re: CatalogStarGenerator does not work in PI 1.8
« Reply #1 on: 2013 May 24 03:18:43 »
I am using this script nearly daily and it do works in PI1.8RC7. Could you please show an screen capture of the configuration dialog?
Offline Yanick B
« Reply #2 on: 2014 February 17 13:16:30 »
I got the same behaviour whenever I use parameters out of norms (Ex: Resolution more than 14"/px).
I would like to make a trivia type of script where one would identify the constellation present into a given picture. This requires to generate images at approximately 12-15mm focal length over an APS-C sensor.
Were there a specific issue with this script? how was it solved? I am using the script with PI Core version 01.08.01.1087 64 bits on a Windows 7, core duo2 machine.
Thanks for your help,
Yanick
Offline Andres.Pozo
« Reply #3 on: 2014 February 17 15:42:55 »
For wide fields you should use the catalog "Bright stars" and a moderate magnitude (i.e. 8).
