Author Topic: Can I determine background ADU?  (Read 5063 times)
Offline swag72
« on: 2013 May 18 00:06:33 »
I am wanting to know the background ADU on my subs. I have looked at the statistics tool and this gives me a mean and median figure ADU value which is presumably of the whole image. is there a way I can get just a background ADU figure with the image in the linear form prior to any processing?
Offline oldwexi
    • Astronomy Pages G.W.
Re: Can I determine background ADU?
« Reply #1 on: 2013 May 18 03:43:15 »
The statistic process works also with Previews. So select with
Preview a Background area only and Statistics will get you the values, i would use the median value.
Aloha
Gerald
Offline chris.bailey
« Reply #2 on: 2013 May 18 09:33:36 »
Sara
OR (and there always more than one way of doing things in PI), click on the little rightward pointing arrow at the very bottom of the screen and pick a Probe sizeof 15, a 16 bit integer range and a readout mode of Median and then go back and left mouse click while moving the mouse around the background of the image. I find this gives a little more feel for any variation.
Chris
Offline swag72
« Reply #3 on: 2013 May 18 12:39:25 »
Two good ideas there - Thanks!!
@Chris - Can you confirm that it's the K figure that's the ADU? I'm liking that method!
« Reply #4 on: 2013 May 19 01:20:05 »
Sara
As long as you have a 16bit camera (I think you do) then a 16 bit integer K is ADU. IF you are trying to measure your sky background levels then you should carry out the measurements on calibrated images. I quite like the probe method as its quick to do a rough measure of a number of open images to get a feel for significant background changes.
Hope that helps
Chris
