Author Topic: DarkStructureEnhance will not run with masked image RC7  (Read 4798 times)
Offline kwalker
Trying to isolate structures using a mask over the background gives me an error that the image is already being processed.
always repeatable.
previous releases allowed masking.
Offline kwalker
Re: DarkStructureEnhance will not run with masked image RC7
« Reply #1 on: 2013 May 10 19:19:38 »
this is a screen shot of the error
Offline cclark
« Reply #2 on: 2013 May 10 21:52:43 »
I just tried the same action and was able to reproduce the error.  Running RC7 on OSX 10.7.5.
« Reply #3 on: 2013 May 11 07:15:33 »
Hi, I believe that it is not a bug. In previous versions, DSE could have been done while a mask was applied, however that mask was not taken into consideration as the process builds its own.
Disable the mask and the script will work fine.
Anyhow a warning would sound better than an error.
Saludos.
Alejandro.
Offline kwalker
« Reply #4 on: 2013 May 11 08:19:48 »
The script does work fine without the mask applied but its a blanket process .
it was nice to be able to selective enhance target areas.
At this time the script will not complete the task ,it just fails.
I like your suggestion of a warning ,but let the script complete.:)
maybe there's way to do this with PixelMath.
« Reply #5 on: 2013 May 11 09:10:18 »
You can see here that there is an explanation of how the script works.
Saludos. Alejandro.
Offline kwalker
« Reply #6 on: 2013 May 11 09:27:59 »
Thank you Alejandro.
Offline kwalker
« Reply #7 on: 2013 May 11 14:51:10 »
Just for reference I was using DSE masked to get into the dust lanes of some targets ,which worked for me.
I got spoiled.
I'm sure there is an alternative to my approach and I'll figure that out in PM or start a new thread if I need help.
DSE is quite functional in its present form for other tasks (as designed).
« Reply #8 on: 2013 May 11 15:00:31 »
well, i suppose you could do the DSE on a clone of the image and then blend the DSE image into the original one while masking your image with the mask you wanted to use...
Offline kwalker
« Reply #9 on: 2013 May 11 15:03:18 »
I never thought of that :)
« Reply #10 on: 2013 May 20 03:28:52 »
Scripts cannot be masked, neither in PI 1.8 nor in previous versions. ATrousWaveletTransform is the right tool to isolate image structures.
Offline kwalker
« Reply #11 on: 2013 May 20 13:01:34 »
thanks Juan.
I was trying to cheat :)
ATrousWaveletTransform works great ,I'll just have to be more patent.
