Author Topic: Batch Preprocessing/ImageIntegration- Can you Sum L Images?  (Read 2914 times)
Offline jerryyyyy
    • Astrobin Images
When I used CCSStacker, I could Sum the L files and did a mean of RGB.  Seems like this script only allows mean/median but no summation.  Am I missing something?
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline Geoff
Re: Batch Preprocessing/ImageIntegration- Can you Sum L Images?
« Reply #1 on: 2013 May 02 22:51:36 »
Sum and mean contain the same information.  If you have the mean of n images, then using PixelMath to multiply all pixel values by n will give you the sum.  If you have the sum of n images, then dividing by n with PixelMath gives you the mean.
Geoff
Don't panic! (Douglas Adams)
« Reply #2 on: 2013 May 03 00:33:43 »
Sum and average are equivalent in terms of signal-to-noise ratio improvement, which is what image integration---and imaging, in general---is all about. By summing frames you get higher levels, and you may think that you have more data in this way. But this is just a false impression. The ratio between signal and noise is the same if you divide the sum result by any nonzero number, as the number of frames for example.
Offline jerryyyyy
    • Astrobin Images
« Reply #3 on: 2013 May 03 06:54:45 »
Had my suspicions about the math.  Thanks for the clarification.
Takahashi 180ED
Astrophysics Mach1
