Author Topic: PI Crashes after clicking "Close All"  (Read 3273 times)
Offline dkopacz
« on: 2013 April 24 18:45:09 »
Occasionally when I select Close All from the menu PixInsight crashes.
The message I get is:
PixInsight Core 1.8.0 RC6 Ripley has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
When I restart the program I get a popup message saying "A Previous instance of the PixInsight Core application crashed. Reusing instance slot #1"
I tried to duplicate the problem by opening a project, opening some files, using the STF tool, etc., but I cannot duplicate the problem. It only seems ot happen after working with the application for some length of time and then selecting "Close All" from the File menu.
My system is a Windows 7 Ultimate SP1 64bit with a 6 core I7 x980 3.33Ghz and 24GB RAM.
I'll continue to try and duplicate the issue and report back here if I can deliberately cause the problem.
Dave
Offline Komet
Re: PI Crashes after clicking "Close All"
« Reply #1 on: 2013 April 30 09:08:00 »
Were any of the images maximised and had you used the Histogram tool on them?
