Author Topic: 1.8RC6 fails to create JavaScript context  (Read 4173 times)
Offline edwardkort
« on: 2013 April 22 20:32:58 »
Hi Juan,
On 1.8RC6 initialization (build 1012), second line is "Failed to create the JavaScript context." Then, all scripts fail with,
"The JavaScript runtime has not been initialized."
I am running:
Windows Vista Home Premium, Service Pack 2, 32-bit.
I does this on a clean install (old version uninstalled prior to installing RC6).
Edward Kort
Offline edwardkort
Re: 1.8RC6 fails to create JavaScript context
« Reply #1 on: 2013 April 22 22:56:07 »
Ok, this appears to be a false alarm.
After rebooting the computer, JavaScript initialized properly and the scripts ran with no error.
It seems that a reboot is necessary to properly register/invoke the JavaScript components.
I don't recall seeing a reboot recommendation in the installation instructions, but I could have missed it.
Anyway, all is good, and I'm a happy camper.
Edward Kort
« Reply #2 on: 2013 April 23 01:02:32 »
Hi Edward,
This problem is reproducible. It only happens in the 32-bit Windows version of PI 1.8.0 RC6. In a couple hours I'll upload a new version, build 2013, which fixes this issue. Sorry for the inconvenience.
In the meanwhile, the workaround is: Run the 32-bit PI Core application. If the JavaScript context fails, exit the application, wait for a few seconds, and run it again. Usually it will work without problems after 2 - 4 attempts.
Offline tcpip
« Reply #3 on: 2013 April 24 05:22:37 »
When will this new version available, because I'm having the same problem and the workaround isn't working.
http://pixinsight.com/forum/index.php?topic=5522.0
Offline edwardkort
« Reply #4 on: 2013 April 27 11:23:22 »
Thanks, Juan.
RC7 fixed the issue, which had become terminal in RC6.
Edward Kort
Offline jerryyyyy
    • Astrobin Images
« Reply #5 on: 2013 April 29 07:10:03 »
Is this fixed for sure now?  I want to upgrade but the upgrade deletes my menu customizations so I want to be sure before upgrading.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
