Author Topic: HaR-RHaGB - NGC2264 with Cone & Fox Nebuales (Pixinsight script)  (Read 3521 times)
Offline roberto_volpi
    • IL MIO SPAZIO
Hello.
It's the first time that I try to combine Ha and RGB images through the appropriate Pixinsight script .
I'm quite satisfied of the result, although I think that the colors are not strictly the same of an RGB image.
I capture my images from a sub-urbane location and so is very important for me to have an alternative to narrow band images (SII-Ha-OIII).
Roberto
Image:
NGC2264 Open Cluster with Cone and Fox Nebuales
Ha 6x30' - RGB 60:50:60 subframes 10' - binning 1
AstroProfessional Apo Triplet 115/800 f/7
Sbig ST2000XM - Baader Planetarium filters
SW EQ6 Pro Synscan
Diffraction Spikes  with crossed wires
Offline Jules
Roberto
I like it, very subtle.
Regards
Julian
    • IL MIO SPAZIO
Thanks Julian.
Roberto
Offline GB_10D
    • http://www.pbase.com/gbachmayer/astropix
Hi Roberto,
Two things come into my mind when I watch you image:
- It is mirrored left to right. For some reason this is the default alignment of the FIT-format, but you can change it in the settings for the FIT-format.
- The green channel is overly emphasized, shifting the usually very pronounced red-blue hue of this nebula towards brown. I'm pretty sure that this can be fixed easily.
Besides that you accomplished a very nicely processed photo.
(Incidentally I imaged the same object one year ago with almost the same field of view ( see http://www.pbase.com/gbachmayer/image/142584422/original), also a HaRGB composite).
Best regards,
Gerhard
    • IL MIO SPAZIO
Many thanks for the suggestions Gerhard
    • IL MIO SPAZIO
I tried to make a new processing
Roberto
