Author Topic: DynamicAlignment and many images  (Read 6747 times)
Offline jerryyyyy
    • Astrobin Images
Re: DynamicAlignment and many images
« Reply #15 on: 2013 April 02 09:09:57 »
OK, I switched over to M106 and the galaxy stacked alright.  I guess there were just too many overlapping stars in the cluster.  I guess eventually I could figure it out, but I am after the principle that thisworks and it seems it does.
I do not like how the image came out with a lot of vignetting.  I will go back to my original flats rather than a CCDStacker master and try to generate a new master first... I have a lot of ploblems with LP and skyglow and this is hard to separate from a flats problem for me.
Anyway, thanks for the help.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline sreilly
« Reply #16 on: 2013 April 02 09:22:49 »
So have you tried DBE to adjust the background? See http://www.harrysastroshed.com/pixinsighthomenewbie.html and look at the DBE video that Harry has done for more information.
-Steve
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline jerryyyyy
    • Astrobin Images
« Reply #17 on: 2013 April 02 10:37:32 »
Yes, I have tried DBE, but I have to say that my best results are with Gradient Exterminator in CS5.  I am using a trick: when I select the DSO, inverse the selection, then run GE 3 times with increasing fineness of the correction.
I just ran this on 14 images on M104 stacked with PI and it came out well (for me).
I think I will try DBE again now that I have a bit more experience.  I wonder if I can deselect the DSO also in PI.
I have some underlying issues insofar as I have changed my imaging set up so I have to collect some new lights to try all this.  I am in a very LPed area new San francisco...
Takahashi 180ED
Astrophysics Mach1
