Author Topic: Viewer on windows  (Read 3219 times)
Offline bitli
Viewer on windows
« on: 2013 March 07 12:20:26 »
Hello,
Can somebody propose a good viewer to windows (7, compatibility 32 bits would be nice)? I know there are plenty of proposals on the web, but I probably have the same requirements as some of you.  Especially I am only interested in the viewer, must support ICC profiles, should display image in a full screen wit h neutral background, not resize the images if not asked for (I prepare them with PI) and allow a simple browsing in a list of file.
So far the best solution I found was to open the list of images in Firefox full screen mode and use the back/forward pages to navigate...
Most viewers give disastrous results on a high gamut display and have bright borders/menus/.... very  distracting for mostly black pictures.
And naturally I would prefer to to have to pay half the price of PI just to look at the images!
-- bitli
Re: Viewer on windows
« Reply #1 on: 2013 March 07 13:41:42 »
In PI, right click on the image>view in full screen,... only a wish for the wish list...
Offline bitli
« Reply #2 on: 2013 March 07 23:17:10 »
I did already add this t othe wish list.
Nevertheless it is annyoing to request a 64 bit environment, install PI and your own key, show the images, then delete the key and PI.... just to show some images in a club
-- bitli
Offline dzso.bacsi
« Reply #3 on: 2013 March 08 01:31:59 »
Well, if I understand your requirements correctly, I think IrfanView http://www.irfanview.com/ with IrfanView Plugins http://www.irfanview.com/plugins.htm do know everything you mentioned, it is free and 32bit. I use it on a Dell U3011 display [117% (CIE1976) / 102% (CIE 1931), 98% (AdobeRGB Coverage), 100% (sRGB Coverage)] with definitely not disastrous results. Sorry, if you've already tried it, but if not IMHO it's worth to have a look.
Offline bitli
« Reply #4 on: 2013 March 08 08:31:46 »
Seems to work fine, thanks. I do not not if it supports ICC profiles, but at least the JPeg image i nSRGB are displayed correctly.
-- bitli
Offline naavis
« Reply #5 on: 2013 March 08 09:32:07 »
-- bitli
IrfanView does support ICC profiles. You just have to enable color management in Options -> Properties/Settings -> Zoom/Color Management.
Samuli Vuorinen
