Author Topic: Save Image File As Behavior Suggestion  (Read 18370 times)
Offline twade
« on: 2008 January 03 19:31:19 »
PTeam,
Would it be possible to change the behavior of the FITS Options dialog the pops up after clicking on the Save button in the Save Image File As dialog box.  Currently, it seems to always default as 32-bit signed integer.  It would be nice if if would automatically default to the files current sample format.  If I want to change it, I'll change it manually; however, 99 times out of 100 I want the sample format to remain the same.
Wade
Offline twade
« Reply #1 on: 2008 January 05 12:18:37 »
PTeam,
It would also be nice if the SampleFormatConversion dialog would default to the current files sample format too.  That way, you know before hand what sample format it has; however, if you go ahead and implement this, you will likely need to add a few more choices to the sample format dialog (e.g. 32-bit signed integer).
Wade
