Author Topic: Win7 64-bit - Ripley 963 Crash on Close PI  (Read 4235 times)
Offline f11
« on: 2013 March 04 00:03:38 »
Just recently I started seeing crashes when closing down PI after saving a new project file.  Its pretty repeatable, in that I've seen it the last four times I've performed the same sequence: Save Project... , then simply File | Exit...
Windows Error dialog on crash:
Problem signature:
  Problem Event Name:   BEX64
  Application Name:   PixInsight.exe
  Application Version:   1.8.0.963
  Application Timestamp:   51007c04
  Fault Module Name:   MSVCR110.dll
  Fault Module Version:   11.0.51106.1
  Fault Module Timestamp:   5098826e
  Exception Offset:   000000000006d4f9
  Exception Code:   c0000417
  Exception Data:   0000000000000000
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   1033
  Additional Information 1:   2e57
  Additional Information 2:   2e5798bc0fe57958c6f35e62f60cc142
  Additional Information 3:   7207
  Additional Information 4:   7207f3ac462bcf8123ffb8a0f13c7472
Rod
Re: Win7 64-bit - Ripley 963 Crash on Close PI
« Reply #1 on: 2013 April 05 17:20:06 »
Hi Rod,
I have managed to reproduce this exact problem a couple times on a laptop with Windows 7 x64. I think you may be interested in my answer to another (perhaps related) issue:
http://pixinsight.com/forum/index.php?topic=5394.msg37419#msg37419
Summarizing, the problem is being caused by Microsoft's C runtime (Visual Studio 2012). Fortunately, it happens only upon application exit on rare occasions (at least for me).
Offline f11
« Reply #2 on: 2013 April 09 13:55:21 »
Thanks for the update, Juan... I see you're looking for data points... have you narrowed it down enough that you don't need any further input?  If its the MSCRuntime module, then it shouldn't appear in Mac/PI installations, I'd assume.  Or is Microsoft that ubiquitous? :)
[ Later edit: just read about the resolution you announced so I won't bother with any more tests. R ]
« Last Edit: 2013 April 09 14:13:45 by f11 »
