Hello all,
I am using PI version 1.08 RC3 on Ubuntu 12.04 (64-bit). There are a few problems that I am facing:
1. If I start a process dialog (e.g. histogram, curves or any of them for that matter), I can use it fine only for first instance of that particular process launch. If I close it and open the same process dialog again, I cannot use it at all - I cannot change parameters or adjust any curves. This problem is 100% reproducible. As a workaround, I keep all process dialogs open but it is really cumbersome to use it that way.
2. I cannot drag an instance of Screen Transfer Function and drop it to Histogram Transformation process.
3. I cannot not see a list of open windows under Window menu item (not sure if this is supposed to be the case or not)
4. I do see occasional crashes. Haven't collected more information on those yet.
Regards
Hemant
