Author Topic: How to Create Master Dark with RAW Files?  (Read 5584 times)
Offline kerrywaz1
    • Spirit Bear Observatory
« on: 2013 February 14 15:33:42 »
I am trying to create a master dark from a set of RAW DSLR files and I must be doing something wrong as I keep getting a white frame.
Can someone please tell me the steps involved?
Kerry
Deep Sky Instruments RC14C
FLI PL16803 w/MOAG + StarlightXpress Ultrastar
Pyxis 3"
Astro Physics AP1200
Tak FSQ-106EDXII
Apogee Alta F16M
Hap Griffin modified Canon EOS 5D Mark II
PixInsight, MaxIm DL, PhotoShop CS5
Re: How to Create Master Dark with RAW Files?
« Reply #1 on: 2013 February 14 17:28:23 »
first, convert the CR2 to fits files using the BatchFormatConversion script. at some point juan put format hints in there, but i think that feature disappeared. so go into the format explorer, double-click "DSLR_RAW" and set it for raw CFA and no black-point conversion.
after converting all your CR2 to fits, load the fits files in ImageIntegration. you can follow the settings advice given here: http://pixinsight.com/tutorials/master-frames/en.html
you have to get the CR2 files into FITS format before integration because II needs to seek within the files in a certain way that's not possible with CR2.
if you want to make a calibrated master dark, instead of BatchFormatConversion you can use ImageCalibration to subtract a master bias from each dark sub. but then of course you have to make the master bias using the recipe above.
Offline kerrywaz1
« Reply #2 on: 2013 February 15 08:45:46 »
Thanks. I found the problem. I had DSLR_RAW set for "Create RAW Bayer image" rather than "Create RAW Bayer CFA image".
--- Kerry
Pyxis 3"
Tak FSQ-106EDXII
Apogee Alta F16M
