www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Black star/rings next to the real stars after Integration
« previous
next »
Print
Pages: [
1
Author
Topic: Black star/rings next to the real stars after Integration (Read 3316 times)
Graham
PixInsight Enthusiast
on:
2013 February 11 18:49:32 »
Howdy,
Before I go of on a tangent thinking that this is a Star Alignment issue, does any one have any idea what would be causing the black circles/stars next to the white stars in my images once I have integrated them.
A sample is below.
Graham. 8)
Logged
Philip de Louraille
PixInsight Addict
Re: Black star/rings next to the real stars after Integration
Reply #1 on:
2013 February 11 21:17:57 »
Did you look at all the frames manually? One hypothesis: you have a double exposure on one frame.
Logged
Philip de Louraille
Alejandro Tombolini
PTeam Member
PixInsight Jedi
Reply #2 on:
2013 February 11 21:50:27 »
...or maybe you have integrated frames that are not aligned.
Saludos. Alejandro.
Logged
pfile
PTeam Member
PixInsight Jedi Grand Master
Reply #3 on:
2013 February 11 22:56:37 »
try loading them all into blink and see if one or two are funny.
Logged
Graham
Reply #4 on:
2013 February 13 00:16:39 »
Howdy.
I have tried all of those things and I cannot say for certain that I can see them in the raw frames. If they are in the raw frames, would that be RBI? The camera is a QHY9 about 3 years old.
Graham.
Logged
Cyclop_si
Newcomer
Reply #5 on:
2013 February 13 01:04:33 »
Try with "clamp" search on QHYCCD forum... you might get some ideas there. Clamp settings in your driver parameters should most probably be "OFF".
Logged
Graham
Reply #6 on:
2013 February 14 01:22:50 »
Hi Cyclop,
I will double check that, however it should be off.
I took a heap of SII frames also, undithered. I will see how those have turned out.
Thanks for your thoughts,
Graham
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
