Author Topic: narrowband with an osc  (Read 3222 times)
Offline vernon tucker
« on: 2013 February 05 19:18:57 »
can someone help i have a osc ATIK cam and i wouod eally like to try narrowband shots is it a bad idea since using a osc to do this   please help.
Offline Geoff
Re: narrowband with an osc
« Reply #1 on: 2013 February 06 03:09:21 »
You can do it. However, you will lose some resolution. For example, the pixels under the red Bayer matrix filters will be the only ones to record anything from your H alpha filter. So you'll be using only a quarter of the pixels of your sensor when you take an Ha shot, a quarter for an SII shot and a half for an OIII shot. Still, I've seen some good stuff from patient people using narrowband with a OSC camera.
Do a google on "narrowband with OSC".  Should turn up a lot, for example
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/3951322/Main/3951322
« Last Edit: 2013 February 06 03:15:16 by Geoff »
Don't panic! (Douglas Adams)
