Author Topic: PI V1.8 RC3 Crash in STF - Picking B-W-MT Points  (Read 3321 times)
Offline f11
« on: 2013 February 05 15:53:45 »
- Win7 Home Premium SP1 in 64-bit mode
- Intel Core2 Quad CPU Q9550 2.83GHz x 2.83GHz
- 8GB Ram
- 1.85 TB disk with 1.5TB free space
PI V1.8 RC3...
- Load a raw FITS image
- start STF from Process Explorer
- no other process open or saved as process icon on desktop
- click "A"in STF to autostretch raw image
- click Black Point Readout "+" button in STF dialog and use to pick a black point on image
- click White Point Readout "+" button in STF dialog and use to pick a white point on image
- click Midtones Readout "+" button in STF dialog and use to pick midtones point on image
I'm getting repeatable program crashes after doing the above (sometimes right after the black point pick, sometimes after the black then white point picks, occassionally after doing all three picks) fairly repeatably.  Doesn't seem to matter if I use a raw, a calibrated, or a calibrated and registered light frame.
Happens while processing any image from any imaging sessions.
The cursor/mouse goes sort of dead for a few seconds after picking the white point, and for quite a few seconds after picking a midtones point... I've never gotten any further than picking the midtones point before a crash occurs.
Windows burps out this crash listing:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   PixInsight.exe
  Application Version:   1.8.0.963
  Application Timestamp:   51007c04
  Fault Module Name:   ntdll.dll
  Fault Module Version:   6.1.7601.17725
  Fault Module Timestamp:   4ec4aa8e
  Exception Code:   c0000005
  Exception Offset:   000000000001861b
  OS Version:   6.1.7601.2.1.0.768.3
  Locale ID:   1033
  Additional Information 1:   f3d2
  Additional Information 2:   f3d2a8942bcd721361ae20fed1320478
  Additional Information 3:   8afb
  Additional Information 4:   8afbf9cdac3b5343dfce16b6d1f5e50b
Rod
Re: PI V1.8 RC3 Crash in STF - Picking B-W-MT Points
« Reply #1 on: 2013 February 11 01:38:36 »
Hi Rod,
Bug confirmed. I'm working on a fix right now, and will release an update as soon as possible. Thank you for reporting it.
« Reply #2 on: 2013 February 11 12:07:12 »
Hi Rod,
This bug is now fixed. I have just released an update for all supported platforms.
Thank you for your help.
Offline f11
« Reply #3 on: 2013 February 11 20:18:59 »
Thanks, Juan... how you guys get so much stuff done so quickly and effectively, I have NO idea... after you finish working on PI, you'll have to write the definitive TimeManagement app  :D
Rod
