Author Topic: Using fake Luminance with DSLR  (Read 4026 times)
Offline jdonald
« on: 2013 February 04 04:57:32 »
Scott Rosen has a nice video on how to do this with a DSLR and I am wondering if this is possible with PI?
http://www.astronomersdoitinthedark.com/dslr_llrgb_tutorial.php
Offline Josh Lake
Re: Using fake Luminance with DSLR
« Reply #1 on: 2013 February 04 08:11:36 »
Sure, I do it all the time, though I wouldn't call it 'fake', just an extracted luminance.
If you have RGB data at any step, you can click the Extract CIE L* Component icon on top or use the Image:Extract menu item. Then you can work separately on the luminance channel and re-combine later with LRGBCombination. This is a very effective technique for gaining both detail (with the work on the L frame) and saturation from the chrominance. The before/after is often significant when the saturation settings are tuned carefully.
« Reply #2 on: 2013 February 04 09:03:11 »
problem is, and juan has tried to explain this to me before, L* is not luminance. it's Lightness, which is really a psychovisual thing.
i think at the very least if you want to do this you should set the RGB weights in the original image to 1:1:1 before extracting L*.
i am still not clear on how, if it's even possible, to make the most correct Luminance data from an RGB image. perhaps it's just the sum of the 3 channels. of course, really recovering the L is impossible (i think) because of the gaps between the R/G/B filters. though on a DSLR there is significant overlap between the filters.
Offline Josh Lake
« Reply #3 on: 2013 February 04 09:46:31 »
I guess in that sense it really is kind of a trick. You're not actually adding anything new to the data, of course... but it does help to increase the saturation and do the chrominance noise reduction step. I didn't even know about this method until seeing it in Vicent's video.
Offline jdonald
« Reply #4 on: 2013 February 04 11:05:34 »
Fake was a strong word.  I should have chosen a different word.
What a great video!  I am going to try this later on my M78.
Thanks for the replies and the support.  I finally got my first ever batchprocess working! in fact I couldn't get DSS to work at all!  I was surprised that I got PI script to work, never had much luck before.
