Hi Georg,
This is actually a bug in the JavaScript engine of PI 1.8.0 RC3.
As you know, GenericImage<> in PCL 2.0 is a reference-counted template class with implicit data sharing. In the following code:
GenericImage<P> image1;
GenericImage<P> image2( image1 );
image2 does not allocate new image data, but just a reference to the image allocated in image1. As soon as a mutable operation is invoked for image2, as for example:
image2.Rescale();
image2 makes a deep copy of its image data, i.e. a uniquely referenced duplicate of the image, before performing the action. In addition, the implicit data sharing mechanism of GenericImage<> is thread-safe (two or more concurrent threads can trigger a deep copy without problems) and non-blocking (thread safety has a marginal performance impact). These features are great for C++ because they allow for more efficient and elegant code: images can be passed by value as function arguments, and can be returned by value from functions, which makes the whole GenericImage<>/ImageVariant branches much more feature-rich and expressive.
However, for JavaScript code this implicit data sharing mechanism is counter-productive. This is because JavaScript already implements its own object referencing system transparently. For example:
var foo = new Image( 100, 100 );
var bar = foo;
In this code, bar is a reference to foo. In other words, bar does not create a new image as a duplicate of the foo image. This is a feature of the JavaScript language. For example, this makes possible the following declaration of a function returning an image:
function CreateWhiteImage( width, height, numChannels )
var image = new Image( width, height, numChannels );
image.fill( 1.0 );
return image;
So the problem here is that PCL's implicit data sharing is duplicating JavaScript's automatic variable referencing, leading to the confusion and undesirable side-effects that you have seen in your tests. The problem is already fixed in PI 1.8.0 RC4, where Image.assign( image ) creates a uniquely referenced duplicate of the currently selected pixel samples in the image argument, as expected.
While I release RC4 (some days), a workaround can be:
var image1 = new Image( ... );
var image2 = new Image( image1.width, image1.height, image1.numberOfChannels, image1.colorSpace );
image2.apply( image1 );
that is, make sure that you allocate the pixel data before copying pixel samples.
