Author Topic: 1.8 RC3 Projects  (Read 4198 times)
1.8 RC3 Projects
« on: 2013 January 29 18:44:18 »
Hi Juan,
Something seems to be wrong when load a project. Besides the process icons that are not present in 1.8 like InterChannel, none of them were opened!.
The project was generated in 1.7 - Linux 64
Saludos. Alejandro.
Re: 1.8 RC3 Projects
« Reply #1 on: 2013 February 02 10:01:26 »
I have still some issues with projects.
This time I have tried to open last project completly done in 1.8 RC3 and something is wrong.
See screen shot.
The only thing that I have done in between is to load and old preference icon that was saved in 1.7 http://www.4shared.com/file/7IF4YVel/PreferencesLinux.html and which add a second directory for swap files.
I try reseting PI with Control button but is the same.
It is strange that other projects can be opened totaly or partially as the posted before.
I doing something wrong?
Saludos.
Alejandro.
Offline FunTomas
    • Astrofoto.sk
« Reply #2 on: 2013 October 17 05:54:25 »
Hello. I have similar problem. This is report from console.
Loading project:
C:/data/data.home/foto/20110913_mozajka_7538/mozajka.xosm
* SHA-1 checksum: df5d7b2cd2e77dda8822671fb915a08ea1c854fe
* Reading project metadata
Created .................... 2013-10-15 20:19:21 UTC
Project generation features:
Include images ............. true
Include previews ........... true
Include interface states ... true
Include icons .............. true
Include text documents ..... true
File checksums (SHA-1) ..... true
Purge existing files ....... false
Check space available ...... true
Workspaces ................. Workspace01 Workspace02 Workspace03 Workspace04
Screen geometry ............ W=1600 H=900
* Loading images
Reading image: b1
Reading image: b2
Reading image: b3
Reading image: b4
Reading image: b5
Reading image: b6
Reading image: b7
* Loading interface states
<* failed *>
*** PCL Win32 System Exception: At address 000007FEFD4B940D with exception code C0000005 :
Access violation: invalid memory write operation at address 0000000000000002
Maybe problem is in using another workspace resolution, than saved in previous project (1920x1080 vs. 1600x900).
Offline FunTomas
    • Astrofoto.sk
« Reply #3 on: 2013 October 17 10:04:22 »
After changing workspace resolution (switch to another display) all project files loaded successfully.
Loading project:
* Loading images
Reading image: b1
Reading image: b2
Reading image: b3
Reading image: b4
Reading image: b5
Reading image: b6
Reading image: b7
* Loading embedded XPSM
Reading icon: Resample_200p_50p_redukcia_sumu
Reading icon: Resample_200p_25p_redukcia_sumu
* Regenerating masking relations
* Updating workspaces
* Project loaded successfully.
All this is done on 01.08.00.1023 64bit RC7
« Reply #4 on: 2013 November 06 01:40:03 »
Hi Tomas,
This is very strange; screen resolution should not make any difference. Does this happen on regular basis, or is it just with this project?
Anyway, the final 1.8.0 version is much more robust on everything related to projects. We are close to the release.
Offline FunTomas
    • Astrofoto.sk
« Reply #5 on: 2013 November 06 03:46:23 »
Hi Juan.
Reopening this project on windows session  at original project resolution is O.K. This happens on regular basis at my system. I use Full HD LCD at work and only native display on laptop at home. Is here any other user with similar workspace configuration to confirm this bug?
I will be happy to try the final  release. May be this release resolve my bug.
