Author Topic: Batch Preprocessing Script  (Read 4636 times)
Offline Nigel Ball
    • Astrophotography by Nigel
« on: 2013 January 28 08:23:01 »
I've recently started using the Batch Preprocessing Script to save considerable time in calibrating my subs
I've encountered a problem in that the Script will only ever calibrate the first set of lights even though I've added Red, Green and Blue light frames. I've reproduced this on my Win 7 Pro 64 bit desktop and Win 7 Pro 32-bit laptop
Has anybody also encountered this problem? If so is there a work around?
Thanks in advance
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Harry page
Re: Batch Preprocessing Script
« Reply #1 on: 2013 January 28 11:42:19 »
Hi Nigel
There is a problem here , but I have only come accross this once and can not repeat it  :-[
Another user has reported it
Perhapes juan could look at your files
Harry
Harry Page
« Reply #2 on: 2013 January 28 12:10:28 »
Sure. I cannot solve a problem if I can't reproduce it. So in these cases I need a (hopefully reduced) data set that causes the problem.
Nigel, can you upload your images (or some of them) where I can download them for testing?
Offline Nigel Ball
« Reply #3 on: 2013 January 28 14:52:51 »
Thanks Juan
Links to zipped files as follows
http://www.nigelaball.com/PixInsight/Masters.zip
http://www.nigelaball.com/PixInsight/LightFrames.zip
Nigel
Nigel Ball
www.nigelaball.com
« Reply #4 on: 2013 January 29 00:47:27 »
Good morning!
I have just tried BPP with your data. By clicking on "Add Files", all the files are automatically selected as master bias, master dark, master flat and light frames, with the correct filters. Then the script works without problems to calibrate, register and integrate the nine light frames, generating the three corresponding master lights. See the attached screenshots.
Are you selecting the Use master bias, Use master dark and Use master flat options (right panel)?
(NB: Note how the default pixel rejection parameters have been useless in this case. Obviously, with just three frames the default Winsorized SC pixel rejection is a bad choice, but this is a good example of why I added the warning dialog about integration with the BPP script.)
« Last Edit: 2013 January 29 00:52:37 by Juan Conejero »
Offline Nigel Ball
« Reply #5 on: 2013 January 29 01:52:03 »
Thanks Juan
Firstly, the version of the BPP script I am running is 1.22, I notice you are running 1.25
Secondly, when I load the Master Flats, they are not automatically selected as Master Flats
I have to manually select Master Bias, Dark and Flat checkboxes. I've tried selecting these checkboxes before using Add Files and still get the same problem of only processing the first filter set.
Nigel
« Last Edit: 2013 January 29 01:59:13 by Nigel Ball »
Nigel Ball
www.nigelaball.com
Offline Nigel Ball
« Reply #6 on: 2013 January 29 02:00:56 »
Juan
I've just found the problem  :D
I noticed in your example that you are registering as well whereas I am only calibrating on my PC here. When I uncheck the Calibrate Only checkbox all Lights are calibrated and registered.
When I check the Calibrate Only check box only the first set of Lights are calibrated
HTH
Nigel
Nigel Ball
www.nigelaball.com
« Reply #7 on: 2013 January 29 02:07:08 »
Hi Nigel,
Yes, I have just checked it, and this also happens in version 1.25. This is obviously a bug, which I'm going to fix immediately. Sorry for the inconvenience.
When you use pre-made master frames for calibration, you have to check the "Use master..." options manually. This is also something that can be improved, since master frames generated by the script can be identified as such automatically. I'll try to add also this improvement along with the bug fix.
Thank you for your help.
Offline Nigel Ball
« Reply #8 on: 2013 January 29 03:15:21 »
Great stuff  :D
Continue the great work you are doing Juan  8)
Nigel Ball
www.nigelaball.com
