Author Topic: Some little processing to share with the forum  (Read 12105 times)
Offline resonance
    • Stelleelettroniche
« on: 2013 January 20 03:59:49 »
Until now the 90% of my Pixinsight knowledge comes from the web, expecially from this forum, so I wanted to share the processing of my last picture, the M42 nebula area, just to pay something back to the web.
The processing comes from some tweaking of the multilayer technique described by RBA on his site (thanks Rogelio :D) and I hope that it can be useful to someone, even only to asses if the processing is wrong or not :D
You can find the technique here
The image of Orion Sword is posted in the gallery forum, I don't know if it is allowed to post it also here.
Emanuele.
Offline Josh Lake
Re: Some little processing to share with the forum
« Reply #1 on: 2013 January 20 05:55:28 »
Excellent image, and fantastic walk-through of your process! Thank you for sharing, that was great.
Offline Lex
  • We do it at night...
« Reply #2 on: 2013 January 20 06:34:52 »
Again, thanks a lot for the share of your procedure, always welcome!
Not forgetting the awesome image!
Well done!
Best
Clear Skies!!
Lex
Offline Jules
« Reply #3 on: 2013 January 20 07:43:43 »
Great article Emanuele
A lot of time and effort into this you have put  :)
Regards
Julian
« Reply #4 on: 2013 January 20 09:02:37 »
Hi Emanuele, nice picture and excellent explanation. Thank for the time for the article and for sharing it!
Best Regards,
Alejandro
Offline Dimitris Platis
« Reply #5 on: 2013 January 20 09:08:57 »
Excellent Emanuele!!!!!!
How much did using a cooled camera help in developing such a beautiful image (noise/stretching etc)?
But from what I can judge from the amount of stretching...u must have extremely good SNR.....(should u wish to share this data with the rest of us who are suffering from months of cloudy nights...u would be appreciated greatly)
Offline sreilly
« Reply #6 on: 2013 January 20 10:17:13 »
Thanks for sharing your technique. Great timing as I've been gathering data for M42. It would be great if this could be packaged and saved under examples and tutorials for others in the future. Just for clarification did you use version 1.7 or 1.8RC?
Thanks again.
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline resonance
« Reply #7 on: 2013 January 20 10:51:12 »
Thank you everybody, your appreciation is the best reward to the time I spent in writing the processing sequence!
I will continue to put other material on the site about the processing of other images (actually there are some post regarding other images processing, but are only in italian language).
Regarding the PI version I'm using the 1.7, I've not yet upgraded to the 1.8. I've filled almost all the hard disk space on my pc, so maybe I will get another pc and then install the new PI version.
Regarding the cooling of the camera, the jump from an un-cooled to a cooled DSLR is huge, data is very clean and of course the stretching capabilities is higher than the one of a "traditional" DSLR.
If you need some informations on dark statisics please ask, I've never gone into that, so I don't even know how to do it :-[
Emanuele.
« Reply #8 on: 2013 January 20 11:26:57 »
Emanuele,
do you know the sensor temp of the cooled DSLR (either the absolute temp OR degrees below ambient)?
You can go to perhaps to a dark frame and measure Process-statistics
Offline dayers
    • The Orlop
« Reply #9 on: 2013 January 20 15:18:58 »
Many thanks, Emanuele, for sharing your workflow with us. It is very much appreciated.
Dave
Dave Ayers
  Stellarvue 80 mm refractor on CG-5 mount, Orion 50mm guide scope. Imaging camera SBIG STF-8300M, guide camera ASI120mm. PHD Guiding. Sequence Generator Pro, PixInsight.
Offline marekc
« Reply #10 on: 2013 January 20 20:05:55 »
This looks like a great tutorial! Thank you very much for sharing it!
- Marek
Offline cs_pixinsight
« Reply #11 on: 2013 January 21 11:36:08 »
Great image.  I read through the tutorial quickly last night, but for some reason I can't get to your site now.
Craig
Offline Raymond
    • Astrophotography
« Reply #12 on: 2013 January 21 11:49:59 »
Excellent image and processing. Thanks a lot for taking the time writing an explicit (and great!) tutorial.
But one question: Do you chose the values for the MMT by trial and error?
Raymond
Raymond
Planewave 14" CDK - 10Micron GM2000HPS
William Optics 110/770 & FF | HEQ5-Pro
Omegon 66/400 | MGEN-Lacerta
Canon 500d mod
« Reply #13 on: 2013 January 21 14:41:10 »
Your site seems to be working again.  This is a great tutorial (thanks for all the screen captures - those help a lot) and one I'll use on my own Orion data to get at the faint nebulosity in that region.
Craig
Offline martin_magnan
    • Messager Céleste
« Reply #14 on: 2013 January 21 18:49:08 »
Thank you very much Emanuele for sharing this "little processing" with us. This is a very valuable workflow.
Martin
TEC140 / AP1200GTO / QSI583wsg - Astrodon LRGB 2 filters / Lodestar X2 Guider / Robofocus
http://www.messagerceleste.com
