Author Topic: HELP - Halo removal with masks?  (Read 7174 times)
Offline Alfredo Beltran
« on: 2013 January 08 17:45:11 »
I'm using currently a trial version of PixInsight and like it very much so far. A year ago I did this image of M45, which came with weird halos from reflections on the optical train:
http://www.astrobin.com/26317/
Can those halos be removed with a mask? I saw the blooming reduction with a mask in this tutorial (http://www.pixinsight.com/examples/NGC6914-CAHA/en.html), but could someone explain a step by step process?
Thanks for your help!
Alfredo
Bogotá, Colombia
iOptron CEM60
Celestron 925 EdgeHD Hyperstar
MicroTouch Focuser
ZWO ASI071 MC Pro
Bogota, Colombia
http://www.flickr.com/photos/alfredo_beltran/
Re: HELP - Halo removal with masks?
« Reply #1 on: 2013 January 08 18:34:04 »
Hi Alfredo,
I'm not even sure it's possible to do what you're asking but it's certainly not a trivial operation. I'm certainly clueless on how to do that, sorry. The trouble is that the artifacts have very smooth transitions from faint to bright which makes them difficult to detect. They look just like DSO's.
Hopefully someone else will have a suggestion but when I run into situations like this like with my hyperstar I try to address it at the source, not in post processing.
Welcome to this forum and PI!
« Reply #2 on: 2013 January 08 18:40:42 »
Hi Sander
I was hoping that this could be removed like the blooming was removed. I just don't know PI enough yet. It's an amazing program.
I hope someone could really help me on this. I have these reflections on every bright star as can be seen in my gallery pictures:
http://www.astrobin.com/users/alfredobeltran/
I don't know if this could be a collimation issue or internal reflections on the C6 SCT. Have you seen this before?
Alfredo
iOptron CEM60
MicroTouch Focuser
ZWO ASI071 MC Pro
Bogota, Colombia
« Reply #3 on: 2013 January 08 18:48:23 »
Hi Alfredo,
halos are very common and hard to avoid. Technically all stars in your images have halos but it's mostly visible with bright stars because the halo signal climbs high enough to be visible. SCTs are notorious for causing them but all optical systems are susceptible.
The artifacts in your Pleiades image aren't halos but a different type of artifact. Ultimately all caused by uncontrolled reflections. I had them with my C11 with hyperstar, called them Abyss Aliens. In the end I decided to skip targets with bright stars.
Anyway, start a little lower with PI and give basic processing a try before trying voodoo magic.
« Reply #4 on: 2013 January 08 18:55:43 »
A very good suggestion Sander!  8)
Nevertheless it's a little sad these reflections appear. There are so many targets with bright stars nearby...
iOptron CEM60
MicroTouch Focuser
ZWO ASI071 MC Pro
Bogota, Colombia
« Reply #5 on: 2013 January 08 19:24:06 »
I understand your pain Alfredo, they have frustrated me too.
« Reply #6 on: 2013 January 08 22:11:43 »
these halos are caused by the main mirror baffle not being black enough on the inside. the solution is apparently to use some flocking paper to line the inside of the baffle.
i was trying to help this guy debug something on astrobin questions. i processed his image and came up with this:
http://www.astrobin.com/27095/
looks familiar, right?
http://questions.astrobin.com/question/601/how-can-i-improve-this-image-unprocessed-stack-of-raw-images-flame-nebula/
check the last answer jmel posted with his link to a thread on cloudynights with pictures of the solution. this problem seems to plague C6s and maybe C5s as well.
« Reply #7 on: 2013 January 09 09:51:00 »
Hi Rob
This is exactly the same kind o reflections I'm having. I really appreciate you sent the link.
It seems indeed that is very common on certain kind of SCT telescopes and the solution appears to be easy to implement.
I will check my telescope to see if it is glossy on the baffle and if it is, I will implement the suggested solution.
Thank you very much indeed.
Best regards
Alfredo
Bogotá, Colombia
« Last Edit: 2013 January 09 10:32:11 by Alfredo Beltran »
iOptron CEM60
MicroTouch Focuser
ZWO ASI071 MC Pro
Bogota, Colombia
« Reply #8 on: 2013 January 09 11:33:04 »
no problem, i hope you can resolve it. astrophotography is hard enough without equipment problems!
