Author Topic: PI Core 1.8.0 Ripley crashes with DBE  (Read 3162 times)
Offline cbradshaw
    • Charlie's Tree House Observatory
« on: 2013 January 07 16:43:17 »
I've had three crashes in a row trying to remove background gradient with DBE.  The only error is "PixInsight Core 1.8.0 Ripley has stopped working. A problem causes the program to stop working correctly.  Windows will close the program and notify you if a solution is available."
The OS is Windows 8 Intel i5-3210M CPU @ 2.5 GHz, 8 GB ram, 64-bit X64 based.
Charlie
Charlie - G11, CGEM, SV115T20, Meade SN8, Mod Canon 20d and T3, QSI 683 WSG,
Offline cbradshaw
Re: PI Core 1.8.0 Ripley crashes with DBE
« Reply #1 on: 2013 January 08 14:13:17 »
Follow-up!  I re-installed 1.7 and everything worked fine.
Charlie
« Reply #2 on: 2013 January 10 16:05:49 »
Hi Charlie,
This problem should be fixed in version 1.8.0 RC2, which will be released this weekend. Thanks for your patience.
Offline johnadig
« Reply #3 on: 2013 January 11 10:10:45 »
My first post, came to find out why I was getting the same error. Maybe I'll install 1.7 also until it's fixed.
Love the program so far!
