Author Topic: January 2013 Contest Images  (Read 21077 times)
Offline Javio
  • Moderator
    • PixInsight
« on: 2013 January 06 15:18:06 »
The January edition of the 2013 PixInsight Monthly Astrophotography Contest is open. Check the contest rules and send your images until January 20th. Please use this post ONLY to submit your images.
Good luck!
Javier Sanchis Muñoz
Offline Javio
  • Moderator
    • PixInsight
Re: January 2013 Contest Images
« Reply #1 on: 2013 January 06 15:20:56 »
[Entry submitted by Howard]
Hello:
I'd like to submit the following rendition of NGC6914 to the December contest (hope I'm not too late!). This image goes all the way back to the summer (not much going on for me since then!), and I posted it to the Gallery in September.
It is the result of 15 hours of exposure taken over many nights from July 24 to August 25. I used a PlaneWave CDK17 and an Apogee U16M camera equipped with Astrodon filters (including a 3-mn Ha), riding atop a Paramount ME, and guided by a Starlight Xpress Lodestar camera through an Astrodon MOAG. The exposures were: 200 minutes in luminance (unbinned); 170 mins in Ha (unbinned); and 130 mins red, 140 mins green, and 260 mins blue (all colours binned 2x2). All subframes were 10 minutes. Image capture was done with ACP controlling TheSkyX, MaxIm DL, and Focusmax.
Processing was done entirely with PixInsight (except for CCDInspector to get a preliminary assay of the quality of the subframes). In addition to image calibration and integration, the major processing algorithms used were HDRMultiscaleTransform, LocalHistogramEqualization, MultiscaleMedianTransform, MorphologicalTransformation (MT), and LRGBCombine. Also noteworthy was the use of Vicent Peris' method for adding Ha to the LRGB (with many thanks to Harry Page for his explanation), and the use of MT with CurvesTransformation and UnsharpMask to reduce star sizes.
Good luck to all the submitters - the quality and variety this round is amazing!
Howard.
The image can also be accessed here.
Offline MikeWiles
« Reply #2 on: 2013 January 09 22:01:55 »
M42 - Hubble Palette
Dates: December 17th, 2012 through January 4th, 2013
Telescope: Explore Scientific ED127CF Refractor - 127mm f/7.5 Carbon Fiber Triplet
Mount: Astro-Physics AP900GTO CP3
Camera: SBIG ST-8300m and SBIG FW8-8300 filter wheel
Guiding: SBIG ST-i Mono and SBIG OAG-8300 off-axis guider
Exposure: 19.1 hours - 3nm filters, subs of 30s, 180s and 1800s
Capture: CCD AutoPilot v5, Maxim DL 5.18
Calibration & Processing: PixInsight 1.7
Offline jeffweiss9
« Reply #3 on: 2013 January 09 23:11:04 »
I'd like to submit this LRGB image of NGC1333:
Scope used and reducer: APM LZOS 130/780 f/6 LW CNC II, W.O. 110/132 FF
Mount Used: Takahashi EM-200 Temma2
Camera Used: SBIG ST-2000XM with Astrodon Gen2 I LRGB
ISO/Exposure: L:21x8min: 2.8hr, RGB 3x11min (2x2): 2.1 hrs; 4.9 hrs total
-Jeff
Offline Jan
    • Astrofotky.cz
« Reply #4 on: 2013 January 19 14:59:11 »
Messier 13, Globular cluster
Faint nebulosities are great, but some of the brighter objects are not easy to photograph either:-) For me, globulars belong to the most beautiful objects of the skies. Hope you will enjoy!
GSO TS 200/4 with ASA 0,73x
Focal lenght 584/ F2.9
Canon 450D Astrodon
Guiding   Megrez 72/ Lacerta
Mount   Gemini G53F
10x8 min. ISO800 + 97x3 min. ISO1600
Stacked by DSS, processed in Pixinsight (standard - backround neutralization, color saturation, histograms etc..
Offline Josh Lake
« Reply #5 on: 2013 January 19 15:33:57 »
M42 in H-Alpha
Equipment: Tak FSQ-106 with SBIG STL-11000
Subs: 20 x 1200 s + 19 x 60 s
Process: HDR Composition, HDRMT, LHE, Unsharp Mask, Morphological Trans, Masked Curves, Atrous
AstroBin Higher Res Link
Screenshots of processing history
