Author Topic: RC1 and scripts errors under OSX  (Read 3927 times)
Offline Philippe B.
    • CIEL AUSTRAL
« on: 2012 December 24 00:48:56 »
Several scripts got errors on this new version
For example, SUBFRAME SELECTOR included in the RC1 got this error :
run --execute-mode=auto "/Applications/PixInsight.app/Contents/src/scripts/SubframeSelector/SubframeSelector.0.5.js"Processing script file: /Applications/PixInsight.app/Contents/src/scripts/SubframeSelector/SubframeSelector.0.5.js*** Error [000]: /Applications/PixInsight.app/Contents/src/scripts/SubframeSelector/SubframeSelectorSectionBar.0.5.js, line 76: Error: Control.Set(): invalid argument type: unsigned integer value expected.
also AIP-SHO scripts shows errors (I ran an old version with success, but not 1.0.6
run --execute-mode=auto "/Applications/PixInsight.app/Contents/src/scripts/SHO-AIP.js"Processing script file: /Applications/PixInsight.app/Contents/src/scripts/SHO-AIP.js*** Error [000]: /Applications/PixInsight.app/Contents/src/scripts/SHO-AIP.js, line 64: Error: Control.Set(): invalid argument type: unsigned integer value expected.
Offline mschuster
Re: RC1 and scripts errors under OSX
« Reply #1 on: 2012 December 24 07:39:15 »
Hi Philippe,
Thank you for the SubframeSelector bug report. I will look in to it.
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #2 on: 2012 December 24 08:34:25 »
Hi Mike
this error just appear  1 time
Now I can use SubframeSlector without problem
cheers
Offline mschuster
« Reply #3 on: 2012 December 24 09:42:21 »
Hi Philippe,
Thank you.
Juan FYI: The code in question is your style sheet support for PJSR section bars. Line 76 contains the call Color.rgbColorToHexString(fgColor) that failed. Apparently this call does not support DataType_UInt32 or the support is intermittent due to an unknown problem.
From the function SectionBar(parent) implementation:
#ifgteq __PI_BUILD__ 854
   var bgColor =
      Settings.readGlobal("InterfaceWindow/SectionBarColor", DataType_UInt32);
   var fgColor =
      Settings.readGlobal("InterfaceWindow/SectionBarTextColor", DataType_UInt32);
#else
   // PJSR access to global settings is broken in PI 1.7
   var bgColor = Color.rgbaColor(192, 192, 168, 255);
   var fgColor = Color.rgbaColor(0, 0, 255, 255);
#endif
   var contractIcon = new Bitmap(":/images/icons/contract_v.png");
   var expandIcon = new Bitmap(":/images/icons/expand_v.png");
   this.backgroundColor = bgColor;
   this.focusStyle = FocusStyle_NoFocus;
   this.label = new Label(this);
   with (this.label) {
      textAlignment = TextAlign_Left | TextAlign_VertCenter;
      styleSheet =
         "QLabel {" +
            "color: " + Color.rgbColorToHexString(fgColor) + "; " +
            "background: " + Color.rgbColorToHexString(bgColor) + ";" +
         "QLabel:disabled { " +
            "color: gray;" +
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #4 on: 2012 December 25 01:38:16 »
an example with same image with same version 0.5 of the script
PI 1.7
StarAlignment: Processing view: light_1x1__10C_1200_0018_cal_1x_target
light_1x1__10C_1200_0018_cal_1x_target:
2487 stars found.
1.802 s
DynamicPSF:  Global context
1 view(s)
2487 star(s)
2337 PSF fittings
1.459 s
7.672s
PI 1.8 (original script code without your modiifcation)
3601 stars found.
2.518 s
** Warning: excessive number of detected stars
DynamicPSF
: Global context
1 view(s)
10000 star(s)
9571 PSF fittings
3.436 s
14.118 s
An idea ?
« Last Edit: 2012 December 25 01:45:05 by Philippe B. »
Offline mschuster
« Reply #5 on: 2012 December 25 08:12:36 »
Hi Philippe,
Thank you for your bug report. I apologize for the problems. I will investigate.
