Author Topic: CCDStack 2 DeBloom Images Will Not Calibrate in Pixinsight  (Read 4093 times)
Offline dgbarar
I am attempting to calibrate debloomed images from CCDStack 2 with Pixinsight using master calibration frames generated in Pixinsight.  If I do not debloom first and use the images as they were generated from CCDSoft, the images calibrate fine.  However, if I run the images through CCDStack 2 and save them in one of their 5 file formats (16 bit Fits Unsigned, 16 bit Fits Signed, 32 Bit Fits, 32 Bit Fits Floating Point, 16 Bit Tiff) I get the same warning image from Pixinsight: Warning.  No correlation between master dark and master flat frames.  And the images do no calibrate.
Any one else run into this problem and has developed a work around?
Don in Phoenix, AZ
AP 155 EDF
Paramount ME
ST10 XME/CFW 8A
Re: CCDStack 2 DeBloom Images Will Not Calibrate in Pixinsight
« Reply #1 on: 2012 December 22 05:54:32 »
Check that the images have the same dimensions.
Offline dgbarar
« Reply #2 on: 2012 December 22 10:42:26 »
Hi Carlos,
Images are the same size.  They calibrate fine directly from CCDSoft.  However, the moment I run them through CCDStack 2 to debloom, I get the a warning from Pixinsight and the images are not calibrated.  If I save them as a tiff from CCDStack after deblooming, the images look normal after an STF--just not calibrated.  All of the other formats available from CCDStack after Pixinsight calibration are grey with very little detail after an STF.
Don
AP 155 EDF
Paramount ME
ST10 XME/CFW 8A
Offline sleshin
« Reply #3 on: 2012 December 22 12:42:13 »
Hi Don and welcome to the forum. I believe this is an issue discussed in the past. See if this post from Juan helps:
http://pixinsight.com/forum/index.php?topic=4408.msg30888#msg30888
Steve Leshin
Stargazer Observatory
Sedona, Arizona
Offline dgbarar
« Reply #4 on: 2012 December 22 15:30:34 »
Hi Steve,
Thanks for the welcome.
Thanks for sending me this thread (can't believe I missed it when I searched earlier).  But this explains exactly what I am observing.  Thanks again for your help.
Don
AP 155 EDF
Paramount ME
ST10 XME/CFW 8A
Offline andyschlei
    • http://www.obsballona.org
« Reply #5 on: 2012 December 23 17:28:00 »
One additional comment -- CCDStack-saved images often don't play well with PixInsight.  CCDStack appears to use the FITS standard differently than PI.
Observatorio de la Ballona
CDK 12.5, NP-101, C-11
AP-1200, AP-900
ST-10 XME, CFW-8, Astrodon v2 filters
Pyxis Rotator, TCF Focuser
