Author Topic: stacking comparison  (Read 3502 times)
Offline herman
stacking comparison
« on: 2012 December 07 19:02:08 »
I've noticed a small difference in PixInsight stacked images compared to MaxIm DL. Actually, it's MaxIm DL that appears different than others... i.e. PI's output seems identical to ImagesPlus output in my example.  Anyway, I've posted my observations here:
http://astro.ihermans.com/test/stacking/stacking-comparison.html
Thoughts?
Jeff
Offline Cheyenne
    • Link to Picasa gallery of my astronomy photos
Re: stacking comparison
« Reply #1 on: 2012 December 08 18:10:37 »
I zoomed in on one of the corners the same amount (8:1) there is a definite difference between the to images.  The MaxImDL seems to have done some sort of blur?
Cheyenne Wills
Takahashi 130 TOA
Losmandy G11
SBIG STF8300M
Canon 20Da
SBIG ST-i + openPHD for autoguiding
« Reply #2 on: 2012 December 08 21:08:42 »
seems like this could be due to the registration algorithm. or did you register all subs with the same software and only do the stacking in the respective programs?
Offline herman
« Reply #3 on: 2012 December 09 16:04:35 »
I registered the subs in PixInsight. I then combined those subs in MaxIm DL,
ImagesPlus, and PixInsight to compare the three programs (my webpage only shows
the MaxIm DL and PixInsight versions... the ImagesPlus stack is identical to the
PixInsight stack). So the only variable in play here is the program used to do
the combine.
Jeff
« Reply #4 on: 2012 December 11 17:46:02 »
okay well there goes my theory :)
dunno then...
