Author Topic: when to do alignment  (Read 2880 times)
Offline herman
« on: 2012 December 07 13:53:44 »
Is a there a general rule of thumb on when to do alignment?  I have typically selected a reference image from one of my Luminance subs and use it for all LRGB subs, then combine each channel.  But another strategy could be to align each channel seperately to a sub from each channel and then align the combined LRGB channels at the end.
Offline dayers
    • The Orlop
Re: when to do alignment
« Reply #1 on: 2012 December 07 17:33:20 »
Hi Herman,
Just StarAlign all your sub-frames at once. Easier. Or you can try it both ways and see which way works for you. That's the beauty of PI. No magic to it: each tool does one thing very well and allows you to try different options.
Dave
Dave Ayers
  Stellarvue 80 mm refractor on CG-5 mount, Orion 50mm guide scope. Imaging camera SBIG STF-8300M, guide camera ASI120mm. PHD Guiding. Sequence Generator Pro, PixInsight.
« Reply #2 on: 2012 December 08 07:48:47 »
It is better to avoid interpolarions as much as you can. Each registration will blur your images a little bit, so just use one frame as reference, and align all other frames to it.
Offline Josh Lake
« Reply #3 on: 2012 December 08 08:00:02 »
I select one of my Luminance frames from the middle of the stack and register everything to that. That way, any drift will take smaller chunks out of the top, bottom, and sides than a big strip out of just one or two sides.
