Author Topic: [PIDOC] example sources not found  (Read 4179 times)
Offline mschuster
Re: [PIDOC] example sources not found
« Reply #1 on: 2012 December 05 04:46:21 »
A while ago I found them. I think it was here. download the tar.gz. I think I used macosx to unpack. If you have trouble let me know and I can put a zip in Dropbox.
mike
http://pixinsight.com/doc/src/
Offline mschuster
« Reply #2 on: 2012 December 05 04:51:45 »
Also note the compile pidoc command in the script editor window is broken on win
Use the script menu command instead.
It places the results in a hard coded scripts subdirectory of the Pi install directory in program files.
You can copy the resulting directory elsewhere but also copy the a side directory of styling files I forgot its name
Offline bitli
« Reply #3 on: 2012 December 05 09:08:06 »
Thanks, I was able to open it just by double clicking on it - I have 7 zip installed (Windows 7).
Now I have to study it...
-- bitli
Offline mschuster
« Reply #4 on: 2012 December 05 10:12:17 »
It will go fast. Juan did a great job with pidoc IMO. Usability, functionality, documentation, samples and formatting, all really nice.
If you get an error when running the compiler from the script menu, relaunch PI as an administrator.
When you create a new pidoc file use a template file. The script editor gives you this option. The template has the required commands included and it is easy to flesh out the details quickly.
When you update embedded png's or jpg's, you may need to flush your browser's cache to see the updates. My version of Safari requires this.
« Last Edit: 2012 December 05 10:24:41 by mschuster »
Offline bitli
« Reply #5 on: 2013 February 16 06:02:02 »
As of PI1.8 RC3 the links (see first post) are still not right (maybe they should be suppressed?)
This not a problem form me as I got the examples for a link above, but this should be quick to correct.
-- bitli
Offline Andres.Pozo
« Reply #6 on: 2013 March 19 11:20:07 »
This problem is still not fixed. I don't know where to find the examples.
Offline mschuster
« Reply #7 on: 2013 March 19 13:02:28 »
Hi Andres,
Increased security maybe has rendered the link I posted unavailable.
Here is a drop dated 2012-01-23 of examples. It should help until Juan responds.
https://dl.dropbox.com/u/109232477/doc-src-20120123.zip
Offline Andres.Pozo
« Reply #8 on: 2013 March 19 13:07:48 »
Thanks Mike  ;) ;)
