Author Topic: What causes this ?  (Read 3654 times)
Offline star gazer
What causes this ?
« on: 2012 November 17 09:25:07 »
Does anyone know what causes this when I process my images?
This is my workflow:
1. convert CR2 to Fits
2. Create master dark
3. Image calibration
4. Debayer
5. Star alignment
6 image integration
The image is the result of step 6 without doing anything else in PI and is a 2:1 crop before STF or any stretching takes place
Re: What causes this ?
« Reply #1 on: 2012 November 17 09:51:28 »
UFOs?  ;)
Check on your original image files if you see something like this in them. Unlikely that Calibration and Integration cause such artifacts without them being somewhere in your base data.
Offline Philip de Louraille
« Reply #2 on: 2012 November 17 18:46:03 »
Look at each image separately and do a ScreenTransferFunction on each. Those details are bound to show up.
Philip de Louraille
Offline star gazer
« Reply #3 on: 2012 November 18 01:37:27 »
Hi Guys,
I don't see them in any images until the final integration. At least if they are there, they are too subtle for me to see. They do seem to be worse were I combine images from separate imaging sessions i.e. where the orientation of the camera is very different between the sessions.
V strange.
« Reply #4 on: 2012 November 18 03:20:26 »
I know of nothing in ImageIntegration that could possibly cause such artefacts. II is basically a weighted addition of the source images, and therefore your "UFOs" most likely are also in the source images.
Offline Raymond
    • Astrophotography
« Reply #5 on: 2012 November 18 05:24:19 »
It's probably the wrong guess, but maybe it can have sth. do to with atmospheric dispersion (the stars should have red/blue borders). Try to extract the R, G and B channel using Channel Extraction. Allign the three images and combine them again.
Raymond
Planewave 14" CDK - 10Micron GM2000HPS
William Optics 110/770 & FF | HEQ5-Pro
Omegon 66/400 | MGEN-Lacerta
Canon 500d mod
Offline Cleon_Wells
« Reply #6 on: 2012 November 18 08:42:33 »
What do the High and Low pixel Rejection images look like, what's your setup?
Cleon
PS I've got a history of imaging UFOs and have never seen anything like this.
Offline martin_magnan
    • Messager Céleste
« Reply #7 on: 2012 November 21 09:08:43 »
In step 5. Star Alignment
make sure the Pixel Interpolation is set to "Bicubic Spline" and not to Auto. The Auto use Lanczos and it does funny stuff around remaining hot pixels and small stars.
Martin
TEC140 / AP1200GTO / QSI583wsg - Astrodon LRGB 2 filters / Lodestar X2 Guider / Robofocus
http://www.messagerceleste.com
