Author Topic: Multiscale Median Transform - help  (Read 6673 times)
Offline catalinfus
    • http://www.catalinfus.ro
« on: 2012 November 17 07:39:34 »
I'm trying for some hours to figure out what is happening with MMT, with no success!! I have an image - TIFF format - of the TSE from some days ago.
The original image is this one :
preview result image is this one :
applied MMT image is this one :
i do not have a clue why the preview result looks so good and when applied, looks like almost nothing happens.
I'm using PI for 5 years+ now and this is the first time I see something like this. Anybody encountered the same issue? Might this be a bug (tiff file problem)?
Will try to save it differently and check the outcome.....but nonetheless there is something little wrong in this.
Thank You
Catalin
Offline catalinfus
Re: Multiscale Median Transform - help
« Reply #1 on: 2012 November 17 08:10:39 »
ATrous Wavelet transform, same issue. TIFF, FIT, whatever.
Thanks in advance!
Catalin
« Reply #2 on: 2012 November 17 08:55:52 »
There have been a couple of posts about this already. The wavelet based processes cannot produce an exact preview due to the way they work. Consider this only an attempt at an approximation.
« Reply #3 on: 2012 November 17 09:36:03 »
Hi Catalin,
You can generate a new preview of the image and adjust the MMT setting on it.
Use real time preview only as a general aproximation an to understand how the parameters affect the images.
BTW, nice picture!.
Alejandro.
Offline catalinfus
« Reply #4 on: 2012 November 17 09:52:42 »
Thanks for answering and Georg, sincerely, I posted here and then in bugs because I really do not know how to treat this. I'm not a casual user of the forums as I can handle my way through Pixinsight pretty easy.
This was the first time I've seen such things happening and I really do not understand why.
I've processed a lot of images, deep-sky, moon, sun...and all the time, the preview window showed the correct output.
Also the HDRMT is not doing the job as in previous versions. I have pretty unexpected results with a lot of noise (just like ATWT and MMT) that simply doesn't make sense....
I mean, I have noise reduction in first/second layer (ATWT or MMT) , on preview pane shows that it works, I apply the instance and the image resulted looks totally opposite, grainy, noisy and missing all detail that has been shown in preview pane...
Thanks Alejandro!! I have some more nice pictures like this and I found out today I can not process them. Photoshop processing is not on my liking.....
Cata
Offline bitli
« Reply #5 on: 2012 November 18 01:19:03 »
Hi Catalin,
A few processes do not always provide fast and useable real-time preview.
You may want to have a look at the script VaryParams (http://pixinsight.com/forum/index.php?topic=4108.msg28562#msg28562). It may help generating images with a few values of the parameters, either to look at the effect of the parameter, or to fine tune the value once you find the approximate one.
This is not a panacea but helped me a few times - warning: I am the author of the script :-)
-- bitli
Offline catalinfus
« Reply #6 on: 2012 November 20 04:33:47 »
Hello Bitli,
thank you very much for your idea and for the script link!!
To tell you frankly, after seeing how this tools are working now, I'm a little bit disappointed but, maybe I'll have the time to learn it someday...
Thank You again to all of you who have responded!!
All the best,
Catalin
« Reply #7 on: 2012 November 20 09:01:16 »
Hi Catalin,
I was looking at your page and your images of the eclipse are very nice! Congratulations!
Saludos,
Alejandro.
Offline catalinfus
« Reply #8 on: 2012 November 21 09:18:25 »
Thanks Alejandro! I'm glad you like them.
Regards
Catalin
