Author Topic: Apply process to several files & Average several files  (Read 3752 times)
Offline luigis
« on: 2012 November 03 18:21:36 »
Hi!
My most sincere apologies if my questions are very basic. I couldn't find a way to do this even if I tried  ???
1) I'm building a lunar mosaic and I would like to apply the Atrouswavelet process (with X parameters) to hundreads of files, is there a way to do this?
2) For another project I have aligned several full-moon images taken with my DSLR and I would like to average them all, I can average with pixelmath but I don't want to have all the files opened in the workspace as the are many of them. Is there a way to select files and do an average ? Image integration seems to fail when there are no stars on the images. I wonder why as it could just do an average of the files without analyzing them ?
Thanks!
Luis
Re: Apply process to several files & Average several files
« Reply #1 on: 2012 November 03 19:10:49 »
Hi Luis
Right click on the workspace>ImageContainer and select the files and complete the container options. Then drag the icon at the workspace and apply the process over the icon.
I can not help with this.
Saludos, Alejandro.
Offline luigis
« Reply #2 on: 2012 November 03 20:52:26 »
Hi Luis
Saludos, Alejandro.
Alejandro, thank you so much, #1 solved and #2 to go  ;)
Offline slang
« Reply #3 on: 2013 April 03 01:04:06 »
Hi.
Sorry for the late reply - just stumbled across this. I am currently experimenting with this, and may have something useful to you.
I have several batches of 10 images of a 6 segment near full moon. For each segment, if I use the script/utilities/fftregistration script, it will register the lunar segments reasonably well, and output relevant .fit files.
I am experimenting with using the standard ImageIntegration routines to combine these. The results are almost promising - I do get an integrated image output, but with 10 input images (per segment) the algorithms don't seem to be coping with seeing differences between frames very well at all.
I am hopeful that there will be a selection of options that are useful, but somehow not holding out much hope...
PS: I'm using PI 1.8-RC5 for this. Previous attempts with fftregistration script (circa PI-1.6 or so) weren't this successful.
Cheers -
Mounts: Orion Atlas 10 eq-g, Explore Scientific G11-PMC8
Scopes: GSO RC8, Astrophysics CCDT67, ES FCD100-80, TSFLAT2
Guiding: ST80/QHY OAG/QHY5L-II-M
Cameras: Canon EOS 450D (IR Mod), QHY8L, QHY163m/QHYFW2-US/Astronomik LRGBHaSiiOii
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #4 on: 2013 April 03 03:32:46 »
Hi Luis!
ImageIntegration works fine without stars  - if you set noise estimation to - "dont care ".
I just integrated/averaged with ImageIntegration prozess my beach Images from the last vacation...
Gerald
