Author Topic: Batch Processing Cannot Add Custom Files  (Read 2934 times)
Offline dave_galera
    • QDigital Astro
« on: 2012 October 29 12:45:10 »
 I am having difficulty loading a custom set of images in to the lights within Batch Processing and the following error is being logged in Process Console:-
BatchProcessing-engine.js Line 516 Error: StackEngine.addCustomFile(): Internal error: Invalid image type: -1
If I close the batch processing and generally try it several times I can eventually get them to load
It seems to work sometimes if I re-select Light Frames in the drop down
I would appreciate any assistance on this problem.
Dave
Dave
Re: Batch Processing Cannot Add Custom Files
« Reply #1 on: 2012 October 30 08:20:35 »
Hi Dave, welcome to the forum!
I am not sure but this seems to be a bug alredy fixed. See: http://pixinsight.com/forum/index.php?topic=3654.msg29957#msg29957
Please check that you are using the latest version of the script.
Regards, Alejandro.
Offline dave_galera
    • QDigital Astro
« Reply #2 on: 2012 October 30 10:18:58 »
Thanks Alejandro, and thanks for the welcome.
I have checked updates and it reports I am all up-to-date. That link you gave seems to report the same problem but in the version I have it still seems to be there, the version of Batch Processing is 1.22
I am using Mac OS10.7 if that helps.
Its not a problem as I now know how I can get around it.
Dave
« Last Edit: 2012 October 30 10:26:16 by dave_galera »
Dave
