Author Topic: How can I apply pixelmath to a series of images?  (Read 3499 times)
Offline gvanhau
« on: 2012 October 25 19:40:18 »
Hello
I was trying to apply pixel math to a series of image files.
To do this I created a image container and then dropped it onto the pixel math, but at the output files pixel math was not applied.
I also tried to do the inverse: apply pixel math to the image container, but the result was the same.
If I set the pixel math check box to create a new image, then new images are created on the workplace with pixel math applied, but saved images are not.
Any Ideas?
Regards
Geert
Geert Vanhauwaert
Offline Ioannis Ioannou
Re: How can I apply pixelmath to a series of images?
« Reply #1 on: 2012 October 25 21:25:08 »
Create an image container, drag the instance (triangle)  icon on the desktop,  open pixelmath, ensure that says "create new Image", apply the pixelmath on the container icon saved on the desktop.
Clear Skies
John (Ioannis)
FSQ106N+Robofocus+QHY-22+SX USB wheel+Baader filters
SX OAG+DSI Pro guiding a NEQ6
PI for the rest :)
Offline gvanhau
« Reply #2 on: 2012 October 26 05:17:08 »
thanks John,
but as I said before, when I do this, I get a lot of new images on my workplace, but images are saved wo pixel math applied.
The images on the worplace are ok, but names are not correlated to original ones, thus this implies a lot of work in identifying (if possible at all) and then rename the images.
Regards
Geert
Geert Vanhauwaert
« Reply #3 on: 2012 October 26 05:38:47 »
Sorry, I may missed what you wrote.
There are two points to check, which both control the output.
Actually if you have the process (pixelmath) producing something usable, then you control the container to apply and output this usable thing to many images to a directory. Take a look on the screenshot, what you have there ?
Clear Skies
John (Ioannis)
PI for the rest :)
« Reply #4 on: 2012 October 26 05:40:10 »
Maybe also posting both pixelmath and image container to take a look ?
Clear Skies
John (Ioannis)
PI for the rest :)
Offline gvanhau
« Reply #5 on: 2012 October 26 20:31:53 »
Hello John
Here are both settings
Regards
Geert
Geert Vanhauwaert
« Reply #6 on: 2012 October 27 12:45:25 »
Intriguing, never tried it like this.
I think that if you change the "Create new image" to "Replace Target image" it will work as expected.
I put a few biases in a folder and in a icon container, and I made a pixelmath to subtract the master bias from them.
With Create new image I'm getting a few new images in the folder same with the original and a few new views in Pix with the results.
If I switch to "Replace new image", I'm getting only a few new images in the folder with the result of the subtraction.
Clear Skies
John (Ioannis)
PI for the rest :)
