Author Topic: Help with manual image calibration  (Read 3297 times)
Offline Flea77
« on: 2012 October 15 19:22:29 »
I have been sucessfully using the BatchPreprocessing script for some time now but ran into a situation where I need to manually combine the images.
I used the CometAlignment module and then realized that I needed to integrate it manually, so I did. I then followed the tutorials to get a master dark, master bias and master flat files. So now I have four files including the integrated lights.
The question is, how do I combine these files into one final image? What module do I load these four files into?
Allan
Offline NKV
Re: Help with manual image calibration
« Reply #1 on: 2012 October 15 22:01:29 »
You must calibrate all Light frames before any processing. ( before integration / registration / etc. )
Offline Flea77
« Reply #2 on: 2012 October 15 23:44:58 »
Is there a tutorial or instructions on how this actually works because I can't seem to find it. I have a set of Nikon DSLR images of a comet I really want to process. Since I have installed the CometAlignment module I assumed that I needed to run it on the lights first so that the frames will line up correctly for stacking. Now it seems you are telling me that is wrong so I have absolutely no idea how to proceed or if any of the files I have are useful.
Allan
« Reply #3 on: 2012 October 16 04:46:42 »
Offline Flea77
« Reply #4 on: 2012 October 16 05:20:22 »
Georg,
That looks pretty good, thanks. I would assume that I would substitute CometAlignment for StarAlignment and the rest as per the instructions, correct?
Allan
« Reply #5 on: 2012 October 16 07:26:49 »
Yes
Offline Flea77
« Reply #6 on: 2012 October 16 18:21:33 »
Thanks, it seems to have functioned without errors. Very much appreciate the help!
Allan
