Author Topic: Help please! ADU Value in pixinsight  (Read 7454 times)
Offline cloudbuster
« on: 2012 October 15 02:03:40 »
Hi All
I'm new to this forum, having had pi for about a year...but have only just started using it properly. i have an Atik313L.
please could someone kindly part with their PI knowledge? im not too good around pi, and have just started ccd imaging. i just dont know how to view the ADU value of my flats.
hoping u can help
cheers
bob ;)
Re: Help please! ADU Value in pixinsight
« Reply #1 on: 2012 October 15 02:32:28 »
Hi Bob,
Welcome to PixInsight Forum. On the bottom of PI's main window, you'll see a little blue arrow that allows you to change readout options. Click the arrow and select "Integer Range > 16-bit" from the popup menu. Now when you move the cursor or click on an image in readout mode (the default mode), you'll get pixel values directly as ADU counts.
See the attached screenshot.
Offline cloudbuster
« Reply #2 on: 2012 October 15 02:49:01 »
hi juan....thanks very much, but i still cant see a value....what is readout mode? im trying to see if my flats have an adu value of around 20,000.
sorry to be a pain!
bob
Offline cloudbuster
« Reply #3 on: 2012 October 15 03:01:53 »
k:0,3419
hi again juan.
the above readout changes as i move the cursor over the image. if so, are my values too high?
also, im mistaken...its an atik 314L that i have!
cheers
bob
« Reply #4 on: 2012 October 15 03:11:19 »
Hi Bob,
"Readout mode" refers to a working mode for interaction with images. In this mode. you can read pixel coordinates and values while you move the cursor over an image, or click on an image and hold the button while you drag the mouse to get a readout preview. See the attached screenshots.
if you want to obtain a robust estimate of the average value of one of your flats, you can use the Statistics tool (available on the Process Explorer window, default Favorites category). On Statistics, you can select the 16-bit range to get ADU values. The mean, median and maximum values will tell you how your flats are numerically.
Offline cloudbuster
« Reply #5 on: 2012 October 15 03:15:27 »
thanks juan
will check that out a little later when i get home.
greatly appreciated
bob :)
« Reply #6 on: 2012 October 15 03:19:27 »
k:0.3419
That is about a 34% of the available dynamic range (or if you prefer thinking in ADU, about 22000 counts). I think it's okay, but I think most people would prefer something closer to the 50% range (around 32000 counts). But I am the guy behind keyboards, algorithms and mountains of source code like the K2 (both in terms of height and danger), so I can be wrong. I'm sure other users with high imaging skills will advice you better.
Offline Geoff
« Reply #7 on: 2012 October 15 03:51:32 »
Hi Bob
What capture program are you using? Usually these will display a histogram of your image as you take it. From the value of the peak you can get a good idea of the ADU value.
Geoff
Don't panic! (Douglas Adams)
Offline cloudbuster
« Reply #8 on: 2012 October 15 11:39:37 »
thanks geoff...and thanks again juan
going into 'statistics' has done the trick!
cheers...til next time :)
bob
