Author Topic: Script compiler error  (Read 3141 times)
Offline hvb356
« on: 2012 October 04 11:29:20 »
yesterday I started to write my first script. Finally with success, but I had to restart my system five or six times. My OS is Win7 on a 4 core, 8 GB Dell Precision 6600.
This problem was reported one year ago
( http://pixinsight.com/forum/index.php?topic=3356.msg23162#msg23162 )
and I'm curious to know, if there is a fix available now. If not, I'm afraid to continue working with my project as I can not always relaibly inspect the syntax rules. I think, this is the job of the compiler!
Regards
Hartmut
TOA-150, ML8300, CFW2-7 w. Astronomik HaLRGB, PDF, EM-400, guiding FS-60 + ST402, ASCOM bsd. image acquisition
Offline mschuster
Re: Script compiler error
« Reply #1 on: 2012 October 04 12:27:43 »
Hartmut,
Yes, this problem still occurs. Relaunch PI and check syntax carefully. I usually comment out newly written portions to help isolate the problem and double check for matching { } and ( ) with syntax highlighting.
Offline hvb356
« Reply #2 on: 2012 October 04 13:14:32 »
Mike,
well, apparently this problem was never classified with high priority but one year later, such a problem should automatically raise its priority or will never disappear from the list.
Thanks for the answer
Hartmut
« Reply #3 on: 2012 October 05 01:51:39 »
Hartmut,
This bug is now fixed in the incoming PixInsight 1.8 version. More information on the original bug report thread.
Offline hvb356
« Reply #4 on: 2012 October 05 11:40:22 »
Hola Juan,
thank you.
Today I checked carefully the code before I started the script and could keep the system alive.
Regards
Hartmut
